Thread: I bought the 1200.1 now what |
New member Username: Ctx
Post Number: 9 Registered: Jun-04
| Posted on Sunday, July 11, 2004 - 12:34 am: |
like it says i just bought a jbl 1200.1 amp and im needing to decide which subs would give me the most bang for my buck its a decision between 4 15in kicker comp's(regular 250-300watt) 3 12in kicker CompVRs(dunno if I need dvc or svc) 2 kicker solo barics not sure what size 10,12,15 L7,or L5,just needs to be 600 watts each im trying to spend around 250$ give or take if you know any dirt cheap sites with good deals tell me |
Silver Member Username: Sploosh56
Post Number: 298 Registered: May-04
| Posted on Sunday, July 11, 2004 - 01:53 am: |
Get 4 15" Kicker Comp's on ebay for $68 each. I have 2 and they pound. |
New member Username: Loudnobnoxious
Post Number: 9 Registered: Jul-04
| Posted on Sunday, July 11, 2004 - 01:59 am: |
first thing: do you want to run it at 1 or 2 ohms? some of the JBL's will run 1 ohm, some won't. |
Post Number: 10 Registered: Jun-04
| Posted on Sunday, July 11, 2004 - 02:08 am: |
mine runs at 2 |
Bronze Member Username: Loudnobnoxious
Post Number: 15 Registered: Jul-04
| Posted on Sunday, July 11, 2004 - 01:09 pm: |
no no no. its rated at 2 ohms but some of them happen to be able to run at 1 ohm. thats good just go ahead and run it at 2 ohm. i'd suggest getting a single solo baric L7 15" in a 6 cube box tuned in the 30's somewhere |
NorthWest,
Michigan
Post Number: 3885 Registered: Dec-03
| Posted on Sunday, July 11, 2004 - 01:17 pm: |
the JBL BP series amps are rated to be 1 ohm stable, but the output is regulated so that tehy put out the same power as with a 2 ohm load. ideally stick to a 2 ohm load at the lowest for nominal impedance. you can get a single 2 ohm sub (or dual 4 ohm coil) rated for 1200 watts, or get a single 4 ohm sub and run the amp at 4 ohms, and 600 watts which will give you a much cooler running amp. you could also look at a pair of 4 ohm subs so that each sub gets 600 watts. a pair of 12" or 15" Adire Brahmas would be a good match.
Bronze Member Username: Ctx
Post Number: 11 Registered: Jun-04
| Posted on Sunday, July 11, 2004 - 09:23 pm: |
im lookin more 4 kicker what kind of subs would i need from them |
Bronze Member Username: Capulina6
Post Number: 26 Registered: Apr-04
| Posted on Sunday, July 11, 2004 - 11:00 pm: |
you could maybe try to get 2 12L5 dual 4 ohm and run the amp at 1ohm giving 600 watts to each sub which is exactly what they need, i dunno just a suggestion |
Post Number: 12 Registered: Jun-04
| Posted on Monday, July 12, 2004 - 12:16 am: |
yea i was leaning towards 2 l5's in a ported box |
