Home > Message Board > Car Audio > Amplifiers > Archive through July 15, 2004 > Remote/12V+ Connection for Amps
Author Thread: Remote/12V+ Connection for Amps
Username: Moe_payne
Can I connect the Remote from the amp to the remote start from the wiring harness of my CD player, and same thing for the 12V+.
Username: Moe_payne
Ignore the Remote part... but i need to know about connecting the 12V+ to the harness behind my CD player
Username: Flashflood
MN
Post Number: 22
an amplifier requires more amps than a CD player.
youve got to run a power wire directly from
the battery to the amplifier to get the proper connection.
its usually either an 8 or a 4 gauge wire,
depending on the amplifiers size
Home > Message Board > Car Audio > Amplifiers > Archive through July 15, 2004 > Remote/12V+ Connection for Amps [ « Previous ] [ Next » ]
