Thread: Hooray...New Amp... Now I need help! |
Bronze Member Username: Spittin2rock
Post Number: 49 Registered: Mar-04
| Posted on Friday, July 09, 2004 - 10:48 pm: |
OK, Got a Mono Amp 1100 watts rms @ 2 ohms. Got 2 DVC 600 watts rms 1200 max. I wanna wire both these subs to this mono amp. What I wanna know is how much wattage will I be getting to both sub from the amp if both the subs are 2 ohms. Amp gets 600 watts rms @ 4 ohms. What will I get to both subs if they're 4 ohms? |
Bronze Member Username: Smokeit
Ft worth,
Texas
Post Number: 75 Registered: Jun-04
| Posted on Friday, July 09, 2004 - 10:51 pm: |
what brand of ampthat matters alot |
Ft worth,
Texas
Post Number: 76 Registered: Jun-04
and the subs |
Post Number: 50 Registered: Mar-04
| Posted on Friday, July 09, 2004 - 10:56 pm: |
Sony Amp and Audiobahn subs |
Ft worth,
Texas
Post Number: 77 Registered: Jun-04
| Posted on Friday, July 09, 2004 - 11:02 pm: |
they both overratted the products and sonys 1100 watts rms is probably 400. glasswolf should have an input on this or jayj thay are both knowledgeable so i will leave the ratings to them. |
Post Number: 51 Registered: Mar-04
| Posted on Friday, July 09, 2004 - 11:23 pm: |
believe me the sony isn't overrated... the audiobahn maybe but serious doubt it if it say it in the manuals |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 373 Registered: Apr-04
| Posted on Saturday, July 10, 2004 - 12:48 am: |
I can re-assure you that sony and audiobahn are over-rated products. Most defanetly. |
Silver Member Username: Jayj
Louisiana
Post Number: 301 Registered: May-04
| Posted on Saturday, July 10, 2004 - 01:13 am: |
Patrick I REALLY REALLY hate to tell you this but that sony amp is ONLY going to put about 250-300watts RMS. I don't care WHAT the book on it says on either one of the products. And you will be VERY lucky if the amp last over a month are two. And the subs FORGET it they sound like sh!t. There will be no helping them even with a 100,000 watt amp. Sorry to break it to you like that but EVERYONE here will tell you the SAME thing. |
NorthWest,
Michigan
Post Number: 3852 Registered: Dec-03
| Posted on Saturday, July 10, 2004 - 01:50 am: |
what is the model of that sony amp? with two 2 ohm subs, at best you'll get a 4 ohm load, which will divide the 4 ohm rated power between the two subs. why on earth did you buy a mono amp and a pair of DVC subs?
Post Number: 52 Registered: Mar-04
| Posted on Saturday, July 10, 2004 - 03:02 pm: |
Didn't buy at all... the Audiobahn I had for about 2 years just sitting around(which I was very satisfied with, especially what I paid for them) and the amp was discontinued from an authorized agent. The amp was a display amp and they had to get rid of it so theyy gave it to me. The model is 1000D and not a sony it's a memphis amp...they gave me a sony manual for some reason and put it in a sony box. I guess they had to get rid of all their memphis products. So I don't know the rating of that amp or if it's a good amp. |
Post Number: 53 Registered: Mar-04
| Posted on Saturday, July 10, 2004 - 03:08 pm: |
Is that amp any good or is it just as bad as sony. I'm trying to find specs for it but can't find crap. I guess that must mean the amp sucks. I'm gonna go back and try to get the right manual. |
Post Number: 54 Registered: Mar-04
| Posted on Saturday, July 10, 2004 - 03:26 pm: |
Ok I'm finding really good stuff on this amp I got. I'm even hearing that it's probably gonna blow my audiobahn in less than a month. I need some input is this amp as good as people says it is. |
NorthWest,
Michigan
Post Number: 3865 Registered: Dec-03
| Posted on Saturday, July 10, 2004 - 03:37 pm: |
Memphis makes pretty nice stuff. Far far better than Sony for sure Now get some good subs and you'll have a pretty tight setup.
Post Number: 55 Registered: Mar-04
| Posted on Saturday, July 10, 2004 - 10:33 pm: |
I just took my time and wired the subs and amp today and my audiobahn quake like hell. I'm sure if I get some JL Audio W7's I'm gonna be very satisfied
Post Number: 56 Registered: Mar-04
| Posted on Saturday, July 10, 2004 - 10:39 pm: |
It sounded nice with the audiobahn's but if I couldn't wire them in series because it almost distorted the subs. I know audiobahn isn't definitely the best but I like em. I know JL Audio's are a whole lot better than audiobahn so I think I'll invest in a pair of W7's. |
Silver Member Username: Jonathan_f
GA
Post Number: 731 Registered: May-04
| Posted on Saturday, July 10, 2004 - 11:34 pm: |
Don't think that W7's are your only option, they are great subs no doubt, but there are subs that are just as good (and you might like them better) for half the price tag. Go listen to Image Dynamics ID max, Eclipse Titaniums, also look at Adire Audio Brahmas and Resonant Engineering X.X.X. series. Many other options out there. |
