Home > Message Board > Car Audio > Amplifiers > Archive through July 15, 2004 > Ok amp question
Author Thread: Ok amp question
Username: Grmncrsnbr
VA
Post Number: 172
Ok im getting two oz audio vector2. They are rated at 250 rms 500 max @ 4 ohm. I am having the hardest time finding an amp that runs at 500w with dynamic power that is mono. S should i try to find a two channel amp for these instead?if i do what would i be looking for? Would i be looking at the 2 ohm or 4 ohm ratings?
Username: Glasswolf
NorthWest, Michigan
Post Number: 3837
any mono amp in the 400-600 watt RMS @ 2 ohm range would work fine.
Home > Message Board > Car Audio > Amplifiers > Archive through July 15, 2004 > Ok amp question [ « Previous ] [ Next » ]
