Thread: Pioneer??? |
New member Username: Spanky
Post Number: 7 Registered: Jul-04
| Posted on Thursday, July 08, 2004 - 10:32 pm: |
does anybody know if the pioneer 7600mp is ne good? |
desenutz Unregistered guest |
| Posted on Saturday, July 10, 2004 - 03:25 pm: |
i got the pioneer premier 750 and its owns! got it for 170!!! |
beamerman Unregistered guest |
| Posted on Saturday, July 10, 2004 - 04:21 pm: |
Can someone tell me what the difference between last year's models (750, 7500, 850, etc.) and the knew versions (760, 860...) is? It seems like this year's models are a step backward in some features as some do not have the customizable screen saver option anymore. Also, can someone tell me why the pioneer premier line seems to be on average about 20 bucks less expensive then the regular line. I know the premier line has a higher voltage on the preamp outputs, but are there some features that are not available in the premier line which would make them less expensive? Thanks to anyone that can help. |
