3 subs...
Username: Deadrabit
Marionville, MO
Post Number: 2578
looking at the re audio srx 10s and srx 12s..
if i go with the 12s i will keep them sealed..
if i get the 10s i will port them
i want something loud and LOW with good sq.
what is ur thoughts on this?
any other subs u would go with?
Username: Mmaudioconcepts
KY USA
Post Number: 709
what are the prices on those subs and what part of the state are you in
Username: Insearchofbass
Post Number: 16223
dc sounds lvl 3 12's they do both very well
Username: Deadrabit
Marionville, MO
Post Number: 2579
r u talking about the level 2s?
those might be a little high for me
http://cgi.ebay.com/3-RE-AUDIO-SRX10D4-10-900-WATT-SQL-CAR-SUBWOOFERS-/390263683418?pt=Car_Subwoofers_Enclosures&hash=item5add87395a
thats what im looking at
i will actually get 6 10 or 6 12s... but i will have them in separate boxes one on the left side and one one the right side of my hatch. i want some space in the middle for an amp rack and some lights and stuff...
i am going to try to make this look cool.. all fiberglass and stuff.
just not sure what i would like more the sound of 12s sealed or 10 ported...
the rsd Phoenix gold subs have also crossed my mind.. but i dn't see them online anymore
Post Number: 16224
the 2's dont hold a candle to the 3's
Post Number: 16225
I dont think youll be happy with the re's you chose
Username: Deadrabit
Marionville, MO
Post Number: 2580
what site sells the level 3s?
how much do they cost?
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 247
get the xls
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16812
http://www.onlinecarstereo.com/CarAudio/cm_18_650_Phoenix_Gold_Component_Car_Sub woofers.aspx
Username: Deadrabit
Marionville, MO
Post Number: 2582
ehhhh my uncle got those rsd 12s for 75
Username: Skdooley
Roanoke, VA Usa
Post Number: 1377
Dc level 3 12's are $179 shipped each.
Username: Rovin
Post Number: 16814
http://www.soundsolutionsaudio.com/store/products/12%22-SSA-DCON-12D4%7B47%7DS4. html
$125 ...
Username: Deadrabit
Marionville, MO
Post Number: 2583
the FI X are on sale for 60 bucks!!! i think thats the best way to go
Username: Deadrabit
Marionville, MO
Post Number: 2584
but still! i am not sure if i should go ported or sealed...
Username: Deadrabit
Marionville, MO
Post Number: 2585
i am from missouri
Username: Rovin
Post Number: 16815
didnt know they had the fiX on sale - u shud jump on those 12s
do 4 ! - lol ...
Username: Skdooley
Roanoke, VA Usa
Post Number: 1380
Those Fi X's are a great deal for the price.
Username: Lord_huggington
Ontario Canada
Post Number: 154
Only use the mentioned subs in a ported box because in a sealed box the response is bad.
For sealed use an LMS motor, like TC Sounds LMS-R, Eclipse SW8210/SW8010/SW8200/SW8000 10's & 12's, Sound Splinter RL-S 12 & 15, etc...
I would use Eclipse SW8210's or SW8010's, as many as you can fit. I would use 1.5 cubes for the 12. These are only $150 on Sonicelectronix, 750W RMS but Eclipse recommends up to 1500W if it's clean power. I had 3 SW8200's in 3.75 cubes sharing 1500W and not that I've heard many great systems but I havn't heard one that got as low and clean. The SW8000 old version models well to QTC .707 at a decent FC - QTC .7091 / FC 28.36Hz F3 28.28Hz in 1.75 cubes - which is fackin' excellent. The efficiency is 84dB though, and the new version is 86dB sensitive. The new version isn't LMS so it shouldn't be anywhere near as clean as an SW8000. I might even try some of those. All of the other subs model kinda weird, for instance the SW8200 in 7.3 cubes is QTC .7069 / FC 23.37Hz / F3 23.38 Hz - very low and flat but 7.3 cubes for a single sealed 12" is too much - it wouldn't handle much power so the SW8000 is an obvious pick.
SW8210
1.8 cubes sealed / recommended 1.5 - 2 cubes
QTC .5
FC 27Hz
F3 42Hz
I've modeled pretty much all subs in many sealed air spaces. You don't get much better than the LMS motors. The RE XXX V4 18 is nice in 6.3 cubes - High QTC at 1.05 but FC is 30Hz and F3 is low at 23Hz. That's a low b!tch.
In the Eclipse old version manuals, they come with bandpass box designs with flat response from 20 to 60Hz. Impressive.
Post Number: 16283
id go with 2 good subs
Username: Drant19
DUB-C, TX
Post Number: 2191
im with sean... a wall of crappy subs is still a wall of CRAPPY subs...
2 subs can be plenty of bass if you install them in the right enclosure and put enough power to them... I say go for the DC subs. those RE subs you are looking at are weak. New RE = Decent at best
Ontario Canada
Post Number: 174
It's a wall?
What subs are crap?
What's the OP driving?
Trunk, everything forewards and sealed off, whatever will fit. Subs that can take plenty of power. Q, XCON, etc.Large box.
Hatch, bunch of sealed Fi X 12's. They're hella cheap.
Ontario Canada
Post Number: 175
There's a review that says DCONs sound and do everything better than SRX's. Here's another.
http://www.diymobileaudio.com/forum/member-product-reviews/57705-ssa-dcon-12-rev iew.html
The DCON 12 is 2.9 dB more efficient than the SRX 12 with 2mm less xmax. Even the SRX 15 is 87.6 dB.
The SRX 12 sealed:
Recommended .75 cubes
QTC .8499
FC 52.78 Hz
F3 45.36 Hz
1 cube
QTC .7602
FC 47.21 Hz
F3 44.14 Hz
1.22 cubes
QTC .7069
FC 43.9 Hz
F3 43.92 Hz
2 cubes
QTC .6009
FC 37.32 Hz
F3 45.03 Hz
4 cubes
QTC .5028
FC 31.22 Hz
F3 48.14 Hz
DCON 12 Sealed
Recommended 1.2 cubes
QTC .6191
FC 52.71 Hz
F3 61.25 Hz
Username: Deadrabit
Marionville, MO
Post Number: 2600
this is not a wall... just something that plays the lows and looks clean
Username: Deadrabit
Marionville, MO
Post Number: 2601
and i don't think i will make it sealed
