Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through April 16, 2004 > Speakers
Author Thread: Speakers
hound dog
What are the best 5x7 speakers?
abc
how strong do you want and how much you willing to spend. But just for the idea I would recommend polk audio.
hounddog
Thanks, I have the Polk DB570's and am fairly pleased. Was just wondering if there is something out there that would blow these away.
Username: Fdafire
I have some Kenwood excelon KFC-XR901 6x9 and they rock with some bass. The 6x8 might be the same.
Username: Tbone
OK
United States
Post Number: 222
I usually forget the 5x7's and install a 5 1/4" component set in the location, it screws into the hole nicely, and would definetly provide better sound.
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through April 16, 2004 > Speakers [ « Previous ] [ Next » ]
