Radio code for a peugeot cd player - PU-2294A
Username: Shane1234567
hiya
i have a peugeot cd player here and need the code, can any1 help please
model - PU-2294A
Serial no - CL0401X0072739
Username: Hay88
Post Number: 1342
Shane1234567
please check for second barcode.
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
