Thread: How will I wire these? |
Bronze Member Username: Jonez788
Post Number: 41 Registered: Jun-04
| Posted on Tuesday, July 06, 2004 - 09:18 pm: |
How will I wire 2 4 ohm DVC subs into a 2 ohm load? Will it have to be parallel? |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 240 Registered: Jun-04
| Posted on Tuesday, July 06, 2004 - 09:45 pm: |
cant do it. I put a wiring diagram post in the subwoofer section. Check it out and it will help ya out. |
Post Number: 43 Registered: Jun-04
| Posted on Tuesday, July 06, 2004 - 09:49 pm: |
Can I with 2 2 ohm DVC? |
Post Number: 44 Registered: Jun-04
| Posted on Tuesday, July 06, 2004 - 10:17 pm: |
Also these are Kicker CVR 12"s |
Houston,
TX
Post Number: 242 Registered: Jun-04
| Posted on Tuesday, July 06, 2004 - 10:24 pm: |
yea with the 2 2ohm dvc you can. check out this link. http://jlaudio.com/tutorials/wiring/index.html |
Houston,
TX
Post Number: 243 Registered: Jun-04
| Posted on Tuesday, July 06, 2004 - 10:29 pm: |
Post Number: 46 Registered: Jun-04
| Posted on Tuesday, July 06, 2004 - 10:58 pm: |
Okay then I guess I'll get those. This just confused me. Option 1: Both voice coils wired in parallel. This is the ideal load for many subwoofer mono amplifiers. In the case of a dual 4 ohm subwoofer, this would produce a 2 ohm load. So I'm assuming it's different with a 2 channel amp.
Houston,
TX
Post Number: 250 Registered: Jun-04
| Posted on Wednesday, July 07, 2004 - 12:56 am: |
Ok a mono amp is usually stable down to 2 ohms. You cant really bridge a mono amp since its already bridged on the inside. A 2 channel amp can handle a 2 ohm load stereo mode but a 4 ohm load in bridged mode. |
