Thread: AHHH! What kit!? Quick! |
Bronze Member Username: Jonez788
Post Number: 35 Registered: Jun-04
| Posted on Tuesday, July 06, 2004 - 07:44 pm: |
I need a 4 gauge kit that can handle 800 watts RMS. WHAT ONE should I get? |
Silver Member Username: Rswan
Post Number: 162 Registered: Apr-04
| Posted on Tuesday, July 06, 2004 - 07:47 pm: |
you have to get a bigger gauge wire. you can try it but i wouldnt reccomend running that much watts on a 4 gauge amp kit, unless it specifically says it can handle 800watts of constant power |
Post Number: 36 Registered: Jun-04
| Posted on Tuesday, July 06, 2004 - 07:55 pm: |
well, im not running it to the trunk, so it won't be as far. Can anybody reccomend me a kit then? |
Silver Member Username: Grmncrsnbr
VA
Post Number: 133 Registered: Jun-04
| Posted on Tuesday, July 06, 2004 - 09:20 pm: |
swan why is it then that most kits for a 1000W amp come with 4g wire? you should be fine with 4g check out http://knukonceptz.com/ |
Post Number: 168 Registered: Apr-04
| Posted on Wednesday, July 07, 2004 - 05:29 pm: |
the bigger the cable the more power can pass through. you need bigger gauge wire than a 4 gauge for a 1000 watt amp, or its a complete waste of wattage. |
