Thread: Wat amp for my 12inch type R?? |
New member Username: Compton2201
Pleasanton,
Ca
Usa
Post Number: 10 Registered: Jun-04
| Posted on Tuesday, July 06, 2004 - 03:46 pm: |
im installin ma first system, i already have my head unit, an alpine cda 9827 but i havent got the slightest idea n wat amp to get. I am about to buy a 12inch alpine type R n i need something like a mono block, 600watt rms wit peaking at 1500 and at preferably 2ohms. Ne one with ne input on that id appreciate it. thanks.. |
Bronze Member Username: Car5_14
Post Number: 70 Registered: May-04
| Posted on Tuesday, July 06, 2004 - 04:29 pm: |
i found KENWOOD EXCELON MONO POWER AMPLIFIER 1600WATT MODEL#KAC-X810D |
Silver Member Username: Jayj
Louisiana
Post Number: 287 Registered: May-04
| Posted on Tuesday, July 06, 2004 - 04:39 pm: |
Kenwood amps are not very good. Jeff do you have 2 12s are one?? Because one type R is 300watts RMS not 600. Also are they the 4ohm DVC version?? |
