Thread: Amp or Sub related problem low sound |
New member Username: Bliztkrieg101
Post Number: 2 Registered: Jul-04
| Posted on Monday, July 05, 2004 - 10:33 pm: |
My subs 12", and 1200w are hooked up to a 900w 2ch amp, and they bump, but not loud, and if I crank radio, the speakers are louder than subs. The subs ARE NOT in a box, they are just lying on bottom of trunk, could that be why? Would i need a sealed box? I tried switting from RCA to hi input, but that didn't do much, in fact it almost killed my amp any suggestions? |
Silver Member Username: Jayj
Louisiana
Post Number: 282 Registered: May-04
| Posted on Monday, July 05, 2004 - 11:01 pm: |
Yeah I got a suggestion DON'T ever run your subs in free air unless they are made for free air usage get them in a box IF they aren't already torn up to hell. Good luck |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 363 Registered: Apr-04
| Posted on Tuesday, July 06, 2004 - 12:30 am: |
You must put the subs in a box, thats where all the sound is at. The sub cant move the air if there is no amount of air to move and push against. |
Post Number: 3 Registered: Jul-04
| Posted on Tuesday, July 06, 2004 - 05:44 pm: |
Really? Jesus, I never knew that, and most of my subs that I have put in systems in past were free air, this one is DEF not, so tell me Are the torn to hell? |
Tucson,
AZ
Post Number: 367 Registered: Apr-04
| Posted on Tuesday, July 06, 2004 - 06:58 pm: |
Well they probably are not damaged, if they still move and there are no signs of outer damage then they are probably good. How long were they in 'free air'. |
Post Number: 5 Registered: Jul-04
| Posted on Tuesday, July 06, 2004 - 07:33 pm: |
About total adding different times together maybe 3 to 5 hours, but in most cases the volume was extremely low, on about 30 and the limit is 63 |
Tucson,
AZ
Post Number: 368 Registered: Apr-04
| Posted on Tuesday, July 06, 2004 - 08:31 pm: |
yeah, they should be alright. Now you need to get a box. If you thought that playing the subs like that gave you SOME to NONE bass then once you box em up they will give you some bass. |
