Home > Message Board > Car Audio > EQs and Crossovers > Archive through March 29, 2005 > Eq on ebay?
Author Thread: Eq on ebay?
Username: Lakers6902
San bernardino, CA
U.S.A.
Post Number: 21
hey everyone im looking to buy a eq for my car, i found this one on ebay, http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3290&item=5707935411&rd=1 &ssPageName=WDVW, i wanted to know if it is worth it or not, please respond fast only 2 days left in auction
also please look at this eq as well and tell me which is better or if both is not worth buying
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3290&item=5708278515&rd=1 &ssPageName=WDVW thanks
Username: Goodstang
Long Island, NY
Post Number: 31
by the looks of things, i would say the second one. for forty bucks, either one would be a good purchase. install it, see how it works. i don't know much about what to look for in an equalizer, but that's something that you can easily wire to your head unit, then screw into your dash below your passenger side glove box.
Username: Glasswolf
NorthWest, Michigan
Post Number: 3773
that BOSS eq in the first link is ugly as balls, and probably wouldn't last 6 months without failing.
that cheap Cuspid crap in the second link is just as bad.
I guess it depends on how cheap you're looking for and how picky you are about buyind decent gear.
San bernardino, CA
U.S.A.
Post Number: 22
well i found another eq wat ima get for sure, its the Pioneer DEQ-7600, i like the features it has and i heard that pioneer is a pretty good brand. I found one for 209 dollars brand new from a local car audio store, please tell me if this is a good item or not, i will probably by this week or next
Username: Glasswolf
NorthWest, Michigan
Post Number: 3793
yes
well worth the expense
Home > Message Board > Car Audio > EQs and Crossovers > Archive through March 29, 2005 > Eq on ebay? [ « Previous ] [ Next » ]
