Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > Any kits WITH...?
Author Thread: Any kits WITH...?
Username: Jonez788
Post Number: 31
Are there any 4 gauge kits with the fuse block all ready installed on the power cable?
Username: Davids2004
Houston, TX
Post Number: 223
No you ususally have to buy it seperate.
Username: Jonez788
Post Number: 32
.....but almost all of the kits have the fuse block in them.
Username: Pat_l
Tucson, AZ
Post Number: 362
Its, not hard to install the fuse holder. Just strip the wires
Username: Jonez788
Post Number: 33
Well, I was helping my friend install his amp and the power cable didn't fit into the fuse block AT ALL. I don't know what was wrong.
Username: Jayj
Louisiana
Post Number: 289
What size wire are you using??
Username: Pat_l
Tucson, AZ
Post Number: 366
All the fuse holders i have delt with i have had no problems like that. Mabey its a really cheap holder. You may need to upgrade to a better holder, its only gonna cost $10.
Username: Jonez788
Post Number: 34
Well, I just ordered a knukoncept one. Glasswolf reccomended it to me. SO it'll be fine.
Username: Pat_l
Tucson, AZ
Post Number: 369
Yes, Knukoncept is really good stuff.
osc
I've tried many times to try and contact Knu, but they never seem to respond to ANY of my emails (I tried emailing them from 3 different addresses with junk mail filter OFF).
Any clue why they haven't responded back? (I want to order wires/kit/rcas from them)
Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > Any kits WITH...? [ « Previous ] [ Next » ]
