Thread: Sony xm-1502sx over current problem |
New member Username: 00mjr
Post Number: 7 Registered: Jun-04
| Posted on Monday, July 05, 2004 - 01:56 am: |
I have eveything hooked up. COreectly and I get no sound out of my subs. The overcurrent light is on? I disconnected the speaker wire rca/speaker wire and just had power going to it. And I still have an over current light on. Whats up? Is this problem inside the amp and is the stereo shop going to be able to repair it? jw thnx |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 224 Registered: Jun-04
| Posted on Monday, July 05, 2004 - 04:06 am: |
if you disconnected your subs and its still on sounds like an internal problem. Maybe try to disconnect and then reconnect everything and see if that works. |
NorthWest,
Michigan
Post Number: 3746 Registered: Dec-03
| Posted on Monday, July 05, 2004 - 11:33 am: |
typical failure sign from a Sony amp. better off just getting a new non-Sony amp.
Post Number: 8 Registered: Jun-04
| Posted on Monday, July 05, 2004 - 04:23 pm: |
Well, I'm taking it to a local car audio store. You think the problem will be a fix up or it just a dead amp. I would hope it would be something like a fuse or something inside. jw thnx |
NorthWest,
Michigan
Post Number: 3755 Registered: Dec-03
| Posted on Monday, July 05, 2004 - 04:29 pm: |
nothing that simple, no. repair cost will liekly be more than buying a new amp. particularly with as cheap as most of teh sony products are. sorry but they have such a high failure rate that this is common to see happen. usually within a few months of purchase.
Post Number: 9 Registered: Jun-04
| Posted on Monday, July 05, 2004 - 04:30 pm: |
my AIM sn is traupfer I'll be on it. If you can explain stuff easier that way. thnx. also just to get some more info to learn. I just started with amp stuff. |
Post Number: 10 Registered: Jun-04
| Posted on Monday, July 05, 2004 - 04:34 pm: |
Well if you can ... if you have AIM can you add me to your list. I need help finding a new one then. The store opens tomara. and I wanna prepare for a replacement! |
NorthWest,
Michigan
Post Number: 3758 Registered: Dec-03
| Posted on Monday, July 05, 2004 - 04:47 pm: |
if you're on a limited budget, look at JBL for amplifiers. they're about the cheapest ones that come to mind worth buying.
Bronze Member Username: Iamduff_87
Michigan
America!
Post Number: 89 Registered: May-04
| Posted on Monday, July 05, 2004 - 05:04 pm: |
also MTX has some good class D amps for good prices. that is what i am getting. a 310Watt @ 2 ohm class D amp for $100. The JBL is about exactly twice that. 600Watts for $220 |
Bronze Member Username: 00mjr
Post Number: 11 Registered: Jun-04
| Posted on Monday, July 05, 2004 - 05:17 pm: |
Ya. I'm looking for an amp that will kick my 2 mtx 12's well for around 150 or below. 100 would be a nice area. I need something similar to my sony xm-1502sx's power (760 w). Becuase when it worked in my sis's suv it was great. So leave something that I won't be wasting my $$ on and that I will be happy with. TY VERY MUCH! |
NorthWest,
Michigan
Post Number: 3761 Registered: Dec-03
| Posted on Monday, July 05, 2004 - 05:36 pm: |
you may want to save a bit more then. you get what ya pay for. $100 won't get you any amplifier worth buying. $200-250 might.
New member Username: Thecigaretteman
Post Number: 1 Registered: Jul-04
| Posted on Wednesday, July 14, 2004 - 01:45 am: |
Ive got the same problem as matt,ive had my sony xplod amp for maybe 2 years now,and im suprised it lasted this long,but my problem is when i turn it up a little my subs shut off,the amp reads "over current" and when i tried to check what it meant i got this..."you are driving too low of an impedance load or the speaker leads are shorted directly",can anybody transate that to somebody thats not too stereo smart? |
Post Number: 2 Registered: Jul-04
| Posted on Wednesday, July 14, 2004 - 01:56 am: |
Sorrt for double posting,but i wanna add that my car is a 1989 mercury grand marquis,its got kind of a weak power supply,my lights dim a lot and so deos my deck,so could this maybe be the problem? Do i maybe need a power cap? |
