Thread: Sonudstream or Kicker |
| Posted on Saturday, July 03, 2004 - 11:56 pm: |
Which amp is better for two JL 12w3v2's. The soundstream xt600.2 or the kicker kx600.2 I know both are quality amps, but I've never actually heard a soundstream amp before. At 4ohms they both push out 150w per sub, is that loud enough to thump. I heard at 2ohms the SQ gets worse(and I want the best SQ I can get out of what I have). Does it get bad enough to hear the difference? Any suggestions are appreciated. |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 217 Registered: Jun-04
| Posted on Sunday, July 04, 2004 - 09:00 pm: |
Are your subs 2 or 4 ohm. |
| Posted on Sunday, July 04, 2004 - 10:23 pm: |
4 ohm |
Silver Member Username: Jayj
Louisiana
Post Number: 281 Registered: May-04
| Posted on Sunday, July 04, 2004 - 10:33 pm: |
Go for the Kicker. Just make sure you can wire your subs safely to the amp. Heres a diagram to help you with that. http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_wi ring.html?subs=2&impedance=DVC4x2 |
