Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > Help wiring subs to my amp
Author Thread: Help wiring subs to my amp
Doug
I have 2 dual voice coil 4ohm + 4ohm Alpine Type S subwoofers. RMS 200 watts max 600 watts. I have a JBL600.1 amp to run them to. Can anyone tell me or show me a website with a diagram for the best way to wire my subs to the amp so that I can get the most out of my subs?
Username: Jayj
Post Number: 258
Doug you will want a 1ohm load with that JBL and you WILL need to turn the gain down so you don't blow the subs. Heres a diagram for you. Good Luck
http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_wi ring.html?subs=2&impedance=DVC4x2 Option #1
Doug
thanx man
Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > Help wiring subs to my amp [ « Previous ] [ Next » ]
