Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > Is factory refurbished as good as new...
Author Thread: Is factory refurbished as good as new, or not?
Username: Skinn
Post Number: 11
I have had an amplifier sent to be fixed by the factory and it worked awsome. It was mine though. Does anyone have any info on buying factory refurbished products. You can get a good deal on some stuff that way.
Username: Grmncrsnbr
VA
Post Number: 110
personnally i wouldnt do it cuz that just means there was probably a problem and it could always happen again
Username: Jonez788
Post Number: 12
I'm getting a refubed one now. Hey, as long as it's got a warranty. No problem for me.
Username: Pat_l
Tucson, AZ
Post Number: 344
Factory re-furb usually means there was a problem with the product before but for instance with a sub they would probably just keep the frame and magnet, rip out the cone and coils and replace them with new. So basically its new and comes with a warranty. I have only had troubles with one sub that was a refurb but i got a 90 day warranty and it settled the problem.
Username: Jamtochristian
Williamsport, Pennsylvania
USA of course!
Post Number: 99
I bought a factory refurbished Kicker amp, and it works awesome. Most of the factory refurbs come with a warranty anyway, so... why not get a refurb?
Username: Skinn
Post Number: 12
Thanks for your info, refurbished items sound alright to me.
Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > Is factory refurbished as good as new... [ « Previous ] [ Next » ]
