Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > Pre-Amp Volt Question
Author Thread: Pre-Amp Volt Question
Username: Iamduff_87
Michigan
America!
Post Number: 65
What is the affects of the different Volts on pre-amp outputs. Does it affect the sound quality? The loudness? The distortion? Would 2 be any different than 2.5? Would 5 be worth the extra money? Why do most companies only have 2 and 2.5? I am just very confused on this whole issue and would appreciate it if someone would give me some good details on this subject. Also what are some of the better Head Units if I only want MP3 capability and decent sound controls for a good price. Not worreid about the Amp in it since I am hooking up my speakers to an external amp.
Michigan
America!
Post Number: 71
bump
any help here would be great ... :-)
Username: Glasswolf
NorthWest, Michigan
Post Number: 3709
good line voltages don't make the system any louder, but they do make for a cleaner signal at the other end of the cable, and they can increase resolution since you'll get more detail in a wider signal band.
usually 4V is about ideal, and the amp inputs have to be matched to teh line voltage for ideal performance.
over 4V and many amps can't accept the signal without being overdriven. lower than 4V and you lose the benefits of the stronger voltage.
If you want a good head unit look at Eclipse.
Michigan
America!
Post Number: 79
thanks wolf
Username: Davids2004
Houston, TX
Post Number: 216
Yea the higher the pre out signal from the headunit the cleaner the signal sent to the amp. Therefore makes the amp works less as it lets you keep the gains down on the amp meaning more efficency.
Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > Pre-Amp Volt Question [ « Previous ] [ Next » ]
