Thread: Square one |
Bronze Member Username: Grmncrsnbr
VA
Post Number: 90 Registered: Jun-04
| Posted on Thursday, July 01, 2004 - 01:24 pm: |
Well here it goes again since my idea was recently shot down. I need to find a good sub amp that will run at 2 Ohm, is mono, and puts out 500W Rms for my subs. Here is the kicker though, I want an amp that has like a matching 2 channel amp for when it comes time to wire my speakers that way its a good clean install. The we channel amp needs to be 100/ch at 4 ohms. Thanks in advance. oh and lets not get too crazy with the pricing |
VA
Post Number: 92 Registered: Jun-04
| Posted on Thursday, July 01, 2004 - 02:16 pm: |
well after doing some looking around on good ol ebay im gonna go with a Phoenix Gold amp. I know they good review on this site so i wont get al turned around and restarted again. |
Silver Member Username: Rswan
Post Number: 151 Registered: Apr-04
| Posted on Thursday, July 01, 2004 - 02:22 pm: |
get an mtx 801d it will be great for what you want too do. they have a really good 2 channel amp that looks exactly the same too. you can get them both for around 600. |
Silver Member Username: Jayj
Post Number: 216 Registered: May-04
| Posted on Thursday, July 01, 2004 - 03:40 pm: |
hey Grmncrsnbr What kind of price range are you looking at. So I can recommend something a little better for you. Oh and sorry about shooting down your other Idea but just telling what I've seen. If Glass or Jonathan told you they was good then go for them. Maybe the company was just having a bad day when they made those amps. |
VA
Post Number: 94 Registered: Jun-04
| Posted on Thursday, July 01, 2004 - 03:52 pm: |
Yeah glass said they werent a bad company, but i know the both of them like PG amps and since i actually found them for a little cheaper i think im gonna go ahead with them. My full system not counting head unit is looking at about $1400 and thats high enough for now I can always upgrade later Glass/Jon if you read this which should i go with PG or Hifonics? |
Post Number: 218 Registered: May-04
| Posted on Thursday, July 01, 2004 - 04:09 pm: |
Hey I found those 2 PG amps. Try to see what kind of price you can get these for on ebay. I also like PG amps never seen are heard a problem about them. Heres 2 links for they amps check them out. http://www.acaraudio.com/product_info.php?cPath=22_36&products_id=870 http://www.acaraudio.com/product_info.php?cPath=22_37&products_id=866 |
Post Number: 219 Registered: May-04
| Posted on Thursday, July 01, 2004 - 04:10 pm: |
VA
Post Number: 96 Registered: Jun-04
| Posted on Thursday, July 01, 2004 - 06:43 pm: |
hahaha those were the exact two i found on ebay the mono was for 210 shipped and the 2 ch was 146 shipped |
Silver Member Username: Grmncrsnbr
VA
Post Number: 111 Registered: Jun-04
| Posted on Friday, July 02, 2004 - 02:46 pm: |
so yeah i lied about wanting those haha the listed values on the their website are max not RMS so once again im back to square one anyone have any ideas? |
