Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > MTX 311D or Xtant A3001
Author Thread: MTX 311D or Xtant A3001
Username: Iamduff_87
Michigan
America!
Post Number: 62
Here is the choice.
An MTX 311D whcih does 155 RMS x 2 @ 2 (Dynamic 14.4v) from a good ebay guy for $89
An Xtant A3001 which does 150 RMS x 2 @ 2 from a off hand guy on ebay for $85.
Which amp would you guys choose and why? They are both mono class D amps.
Username: Jayj
Post Number: 215
I would choose the MTX. Because you said you could get it from a good ebay guy.
Michigan
America!
Post Number: 63
Thanks Jay! And does the car run at 14.4 V when running as opposed to 12 V when off. THat is what i was told. THe MTX runs at 155 x 2 @ 2 at 14.4 and 100 x 2 @ 2 at 12 v....was wondering which one i would get.
Username: Jayj
Post Number: 220
John when you car is off you'll get 12v when it is at idle you should get 13.8-14.4v when your car is above idle you should get a straight 14.4v. On my truck it idles with 14.4 so I would depending on the car. The best way to find out is get a DMM and check it yourself.
Michigan
America!
Post Number: 64
how much do DMMs cost.. and where can i get one?
Username: Jayj
Post Number: 231
I got a cheapy from Walmart for 15 bucks. It works great.
Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > MTX 311D or Xtant A3001 [ « Previous ] [ Next » ]
