Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > '03 Accord Cpe EX tweeter upgrade
Author Thread: '03 Accord Cpe EX tweeter upgrade
Ipribadi
I have a 7th gen '03 AV6 EX 5A Cpe and wish to upgrade the stock speakers ..
I've read that the front tweeters are 3/4" and are easy to replace. This is my upgrade target for now.
My main concern is that the tweeters that I replace them with will not have the same sensitivity as the stock ones .. thus being imbalanced with the front 6.5" mids.
I plan to keep the stock in-line high pass filter to ensure flat freq response with the mids.
Has anyone done this b4?
I'm thinking I should have a 90dB or 91dB sensitive 3/4" tweeter. Anyone can confirm? Would a 1" tweeter fit?
I'm not driving any amps for these speakers, thus it's just the 30wx4 head unit.
I also like smooth highs .. thus I'm trying to stay away from metal dome tweeters.. and more leaned towards silk dome tweeters.
Any recommendations? Anything would help.
Thanks!
I think you posted in the wrong section. You need that in the speaker section.
Username: Demigod33
Post Number: 78
i have a new accord, just up grade your system and stop being cheap
Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > '03 Accord Cpe EX tweeter upgrade [ « Previous ] [ Next » ]
