Thread: Amp Opinion for Kappa Perfects? |
Bronze Member Username: Loudon
Post Number: 19 Registered: Jun-04
| Posted on Wednesday, June 30, 2004 - 11:12 pm: |
What is the best possible AMP for 2 Kappa Perfects? |
NorthWest,
Michigan
Post Number: 3637 Registered: Dec-03
| Posted on Thursday, July 01, 2004 - 09:39 am: |
that totally depends on your wallet THE best? I'd look at Zapco's Competition series amps, or McIntosh.
Post Number: 20 Registered: Jun-04
| Posted on Thursday, July 01, 2004 - 10:35 am: |
ok dont have the wallet for those amps... although ive seen a Zapco Amp power 2 L7's to maxiumum wattage ... but i need something more in the 200-300 dollar price range |
Bronze Member Username: Grmncrsnbr
VA
Post Number: 88 Registered: Jun-04
| Posted on Thursday, July 01, 2004 - 10:47 am: |
im gonna run mine with hifonics amps |
Bronze Member Username: Jamtochristian
Williamsport,
Pennsylvania
USA of course!
Post Number: 93 Registered: Mar-04
| Posted on Thursday, July 01, 2004 - 05:19 pm: |
I've heard that the Hifonic amps don't have that great of reliability. I love my kicker amp, and ask most people. The Kickers are very well built, when used properly, they hold up well. The KX450.2 should do nicely. It has a little more than you'll NEED per say, but it will do well. In your budget too. If you're not a fan of Kicker amps(which i was skeptical before I bought mine(its great)). Then I'd say go with the MTX thunder502. These are both nice amps and within your budget. |
Williamsport,
Pennsylvania
USA of course!
Post Number: 94 Registered: Mar-04
| Posted on Thursday, July 01, 2004 - 05:20 pm: |
Oh... if forgot, if you're looking to power TWO SETS of perfects, not just 2 speakers, then I'd go with the KX800.4. It'll push 100 RMS to each of your 4 speakers. |
Post Number: 23 Registered: Jun-04
| Posted on Thursday, July 01, 2004 - 10:24 pm: |
ok thats good for my speakers .. what about 2 Kappa Subs?
