Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > Which amp is best?
Author Thread: Which amp is best?
Username: Car5_14
Post Number: 45
WHich amp is best between the 3?:
1.Audiobahn A2300HCT
2.Rockfordfosgate P8004
3.Kicker KX1200.1
Username: Jayj
Post Number: 199
The Kicker. The others are pretty much crap.
GK
Both the Rockfordfosgate & Kikcker amps are excellent but the RF is a 4 ch and the Kicker is a mono amp and would be use in differant applications.
More info about your intended system would help !
Audiobahn has been descussed on other threads on this site and is not recommended for those reasons.
regards GK
Username: Glasswolf
NorthWest, Michigan
Post Number: 3619
plus the kicker needs a 1 ohm load to put out 1200 watts.
very different uses for those amps indeed
Username: Car5_14
Post Number: 46
is the kicker a 2 channel amp? and whats a mono amp?
Username: Car5_14
Post Number: 47
and how would u hook up ur sub or subs or w/e u do to this: 2400 watts x 1 @ 1 ohm mono
and does someone know about many fuses and how big the fuses are on the kicker amp?
Username: Grmncrsnbr
VA
Post Number: 71
A mono amp only puts out one channel which makes them great for subs and no the kicker is a mono amp.
No about hooking them up it all depends on this:
How many subs you get
How many voice coils each of them has
The ohm rating of the voice coils.
Depending on what your working with you will have to use a certain type of amp.
here use this webpage it has a wiring diagram for common ohm sub ratings
http://www.crutchfieldadvisor.com/S-qXNTJGsFxKv/learningcenter/car/subwoofers_wi ring.html
Username: Car5_14
Post Number: 49
doesnt say nothin about 1 ohms though?
VA
Post Number: 72
your not going to have 1 ohm speakers you need to look in each section on the left side of the picture itll say an ohm rating with nothing else by it this is what ohm rating the amp should have. for example if you look under 2 subwoofers and click dual voice coil - 4 ohms X 2 youll see that you can run them off of a 1 ohm amp
Username: Car5_14
Post Number: 53
ok this is the ratings:
4 ohm stereo = 300 X 2
2 ohm stereo = 600 X 2
1 ohm stereo = 900 X 2
4 ohm mono = 600 X 1
2 ohm mono = 1200 X 1
1 ohm mono = 2400 X 1
Username: Car5_14
Post Number: 54
help me which one is better and how to set it up?
Username: Car5_14
Post Number: 55
help me which one is better and how to set it up? and can u run 2 subs to a mono d class amp
Username: Car5_14
Post Number: 56
which one is best and how do i set it up and can u run 2 subs to a mono d class amp?
VA
Post Number: 74
you need to figure out what subs you want first its much easier to get an amp based on the subs you want. So do you know what and how many you want if so that info is needed in order to go any farther.
what i am going to be running is 2 subs that are 4 ohm single voice coils a peice so i will need a mono amp that runs at 2 ohms.
tell us what subs you want or have.
Username: Car5_14
Post Number: 57
i have 4 ohm dual voice coils and i have 2 subs?
so how would i work it up?
VA
Post Number: 75
its easy look at that chart i sent you under 2 subs 4ohm X 2
that will should how to wire them and what the ohm load on the amp is.
then you should find a mono amp that puts out the same wattage as your two subs combined at the ohms you wanna run. I would recommend a 1 ohm set up so now just find the amp that has the right wattage and your all set.
Username: Car5_14
Post Number: 58
ok thanx man :D
VA
Post Number: 76
no problem enjoy dude
Home > Message Board > Car Audio > Amplifiers > Archive through July 08, 2004 > Which amp is best? [ « Previous ] [ Next » ]
