Thread: Copying Sound Characteristics |
Unregistered guest |
| Posted on Monday, June 28, 2004 - 08:45 am: |
Well my home systems is: HK230 (High Current amp) 65 watts per channel in stereo mode infiinty primus 2 ways dual 5.25 woofer .5 tweeter Infinity 10 inch 250 watts ported sub NOw......I really like this sound...and I wanna bring a similar sound to my car. Would you fellows either go with: amp a - audiobahn 35watts X4 high current amp amp b - jbl 4 X 75 channel amp amp c - infinty 4X75 channel amp amp d - some other high current amp amp e - some other amp wired with speakers in parrallel. Any input is appreiated.... and if you have other suggestions as for the rest of the system i'd like to hear em.. peace |
Bronze Member Username: Car5_14
Post Number: 52 Registered: May-04
| Posted on Wednesday, June 30, 2004 - 01:21 pm: |
ur at the wrong subject this is for CAR AUDIO |
| Posted on Thursday, July 01, 2004 - 08:48 am: |
Yea I am looking for advice on purchasing a CAR amp you fa king D!psh!t. Oh, and I wouldn't tell anyone you own a neon because that is a faggy car. |
NorthWest,
Michigan
Post Number: 3632 Registered: Dec-03
| Posted on Thursday, July 01, 2004 - 09:01 am: |
amp will depend on budget. I'd look at kicker or MTX 4 channel amps both make better amps than all of the brands you listed. JBL is the bottom end of good. Infinity is better known for speakers than amps audiobahn isn't worth wasting money on
