Thread: Amplifier Questions |
Bronze Member Username: Iamduff_87
Michigan
America!
Post Number: 47 Registered: May-04
| Posted on Monday, June 21, 2004 - 06:43 pm: |
Just to make sure i am calculating this correct. A mono amp listed at 150 Watts x 1 @ 4 ohm and 300 Watts x 1 @ 2 ohms would break down to 150 Watts x 2 @ 2 ohm split into 2 4ohm svc subs. If that is correct here are my amp choices I have limited it down to. Price is a big factor. What would you recommend. RF P3001 (new RF) $149 150Wx2 RF 301M (older RF) $129 150Wx2 JBL 600.1 $220 300Wx2 MTX RT251D $119 100Wx2 MTX Thunder251D $179 125Wx2 I figured with this that the JBL is a little to much for me and that the RF 301M is the best deal. i wonder why the older RF is cheaper with same output. i also thought older RF amps are underrated so that seems by far the best deal. please help please... thanks -DUff |
NorthWest,
Michigan
Post Number: 3461 Registered: Dec-03
| Posted on Monday, June 21, 2004 - 08:25 pm: |
your calculations are correct.
Michigan
America!
Post Number: 48 Registered: May-04
| Posted on Monday, June 21, 2004 - 08:46 pm: |
which amplifier would you suggest Glass?? |
Silver Member Username: Sploosh56
Post Number: 194 Registered: May-04
| Posted on Monday, June 21, 2004 - 10:29 pm: |
I'd go with the older RF series. You could always try a JBL 300.1 amp. What kind of subs are you running. |
Silver Member Username: Its_bacon12
Hfl,
Ny
Usa
Post Number: 719 Registered: Dec-03
| Posted on Monday, June 21, 2004 - 11:06 pm: |
this is true - a jbl 300.1 will put out 300w rms at 1 or 2 ohms |
Michigan
America!
Post Number: 49 Registered: May-04
| Posted on Tuesday, June 22, 2004 - 11:27 pm: |
i will be running 2 12" Sonys capable of a RATED 350 RMS but i dont want to try to push that much into them and dont think it is necessary. i also do not have the money available to buy an amp over 175 anyway . poor high school kid who just lost his job here. gotta love the SHH iat in our lives huh -DUff |
NorthWest,
Michigan
Post Number: 3476 Registered: Dec-03
| Posted on Wednesday, June 23, 2004 - 10:10 am: |
of the amps you listed, the best made one is the MTX Thunder line.
Michigan
America!
Post Number: 51 Registered: May-04
| Posted on Sunday, June 27, 2004 - 12:46 am: |
hey glass. you said the best made one is the MTX Thunder line. Is that the best buy of all these is more of the question im asking. And why is that ... last longer, underrated, better sound??? and is the RF 301M an old Rockford? If so arent they some of the best amps made still?? Thanks Glass |
Silver Member Username: Jonathan_f
GA
Post Number: 592 Registered: May-04
| Posted on Sunday, June 27, 2004 - 01:26 am: |
Quality of the amp, sound quality, reliability, RF has slumped in their quality since they went commercial, and that 301M is included. JBL is good, but not the sound quality of the MTX. Early, early 90's RF was the good stuff, very hard to find now. |
NorthWest,
Michigan
Post Number: 3566 Registered: Dec-03
| Posted on Sunday, June 27, 2004 - 11:06 am: |
durability, features, component spec quality, things like that.. all equates to a better overall amp. JBL is good, but they are basically the bottom end of things I recommend because they're affordable to jsut about anyone. They lack some things like infrasonic filtration which makes a big difference to a ported box.
Michigan
America!
Post Number: 53 Registered: May-04
| Posted on Monday, June 28, 2004 - 05:04 pm: |
glass. is the road thunder series as good as the thunder? MTX RT251D to be exact. and is there a lower sized amp below the JBL 600.1?? |
NorthWest,
Michigan
Post Number: 3587 Registered: Dec-03
| Posted on Monday, June 28, 2004 - 06:24 pm: |
road thunder is their "cheapy" product line, and not that great in general. there is a 300.1 and 150.1 yes
Michigan
America!
Post Number: 54 Registered: May-04
| Posted on Monday, June 28, 2004 - 07:59 pm: |
thanks ur so great |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 193 Registered: Jun-04
| Posted on Monday, June 28, 2004 - 09:30 pm: |
Ill tell you a better amp for under 150.00 Xtant A3001T. It can be had on ebay for around 120.00+ shipping. This amp will give you 300 rms at 2 ohms. Good thing about this amp is it puts out 300 rms from 12.5-14.4 volts at 2 ohms kinda of like JL amps and ive heard these amps are underrated. So I would go with that one before the other ones. |
NorthWest,
Michigan
Post Number: 3602 Registered: Dec-03
| Posted on Tuesday, June 29, 2004 - 09:22 am: |
there ya go. Xtant makes nice amplifiers
Michigan
America!
Post Number: 55 Registered: May-04
| Posted on Tuesday, June 29, 2004 - 11:34 pm: |
glass where would you rate Xtant in comparison to other amps?? above the new rockford? below MTX? thanks
New member Username: Xgrizzlyx
Post Number: 2 Registered: Jul-04
| Posted on Friday, July 02, 2004 - 03:59 pm: |
Find a Cadence dealer You will be very happy you did. hehe purchase yourself cadence subs aswell. I've witnessed MTX subs being shattered to pcs by a cadence amp. THe amp was put in to the person setup replacing there kicker amp at the same rating and the cadence ripped them up. The person went home with the amp and a new subs and was very happy. |
