Home > Message Board > Car Audio > Amplifiers > Problem with alpine m1000 amput
Author Thread: Problem with alpine m1000 amput
Username: Sleiser5
I had it hooked up to two 15in subs and it worked fine for a month. Now it keeps blowing the fuse in the power wire from the battery to the amp. Someone at a local place said the ground wire wasn't hooked up right. I moved it b it is still doing it so I don't think that that is the problem. Does anyone have any ideas for me to try.
Username: Skdooley
Roanoke, VA
Usa
Post Number: 65
What ohm load are the subs running to the amp at? Is the amp 1 ohm stable? What size wire do you have running the amp? What size fuse? Is your gain set correctly? What is your amp now grounded to?
Username: Sleiser5
not sure what load the subs are running. don't know if amp is 1 ohm stable( how do i tell). the wire is 4 gauge, the fuse is 100 amps. the amp is grounded to the inside of the trunk and what should the gain be set to.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Amplifiers > Problem with alpine m1000 amput [ « Previous ] [ Next » ]
