Home > Message Board > Car Audio > Subwoofers > Hifonics Amp Internal Fault
Author Thread: Hifonics Amp Internal Fault
Username: Comerz
Post Number: 166
My hifonics amp protect light came on. I did a process of elimination and it is not my sub.
My local audio shop told me it was an internal fault. I am buyign the same amp soon because it matches my alpine type R the way i like it.
I dont want to run into this problem again so im just wondering why this was caused and what i can do to prevent it, or even, look into another amp?
Let me know what you guys think
Username: Dangeranger
Fredericktown, Ohio
United States
Post Number: 174
when your amp turns on does it go straight into protect? or does it take the music playing to kick it into protect?
Username: Somedonniedude
Illinois
Braaap MX
Post Number: 2809
thats what hifonics amps are known for, breaking for no reason.
do yourself a favor and by something more reliable. how much are you looking to spend on an amp? what coils does your sub have?
Username: Skateguy92
Post Number: 107
Im pretty sure mine did the same, it lasted a while though so I chalked it up as a win for the 100 a spent on it.
Username: Nd4spd18
Philadelphia, PA
Post Number: 10720
If you don't want problems again get a better amp.... hifonics amps are relatively low quality
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Subwoofers > Hifonics Amp Internal Fault [ « Previous ] [ Next » ]
