Home > Message Board > Car Audio > Amplifiers > Need an amp opinion about 600Wrms@2ohm
Author Thread: Need an amp opinion about 600Wrms@2ohm
Username: Sciullo779
Pittsburgh, Pa
Usa
ok guys you all know more about brands then me so here goes....
i have 2 powerbass M-10's in a ported box. each sub is rated at 300Wrms@4ohm 600W@4ohm max
they currently are running in a parallel at 600wrms@2ohm 1200W max
im debating on these amps
this ones a little underpowered but its on the safe side i guess, and it was recommended by this community previously.....
http://www.onlinecarstereo.com/CarAu..._DSC10001.aspx
higher powered model-same price- i kinda like this one because i can expand my system but i dont want to blow my subs before im ready to upgrade
http://www.onlinecarstereo.com/CarAu..._DSC15001.aspx
honestly this one looks **** near perfect for what i need but idk once again about the brands
http://www.onlinecarstereo.com/CarAu...d_RSd6001.aspx
seriously considering this one
http://www.onlinecarstereo.com/CarAudio/p_20525_Infinity_1600a_5cRB.aspx
thanks for the help guys
and please try to keep any other suggestions at $250 and under
Pittsburgh, Pa
Usa
talk about a useless forum
Username: Wackzirth88
K-town, Il
U.S.
Post Number: 187
go to the subwoofer forum. no one really uses the amp forum.
anyways ill try to help u. none of ur links worked for me.first i have a couple questions. are ur subs single or dual voice coil? 4 ohm or 2 ohm? wats ur budget on a amp? answer those for me and ill have some suggestions for u.
Username: Drbizerk
Okc, Ok
U.s.
Post Number: 12
non worked for me either. i have the perfect amp for you... old school kicker zr360. 1993 made in the usa and in damn near perfect condition. i've been using it on two 10" Powerbass 2xls and its more than enough for those
Username: Rovin
1 15 = 152.5 DBs ...
Trinidad & T...
Post Number: 15650
only the infinity link worked ...
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Amplifiers > Need an amp opinion about 600Wrms@2ohm [ « Previous ] [ Next » ]
