Home > Message Board > Car Audio > Subwoofers > Why did my voice coils blow???
Author Thread: Why did my voice coils blow???
Username: West_21
Amarillo, Tx
I have a elemental desings amp, specs-
elemental design
Nine.1
Model Name : NINe.1 Amplifier
RMS Power @ 12.5v :
1200W x 1 @ 1 Ohm
900W x 1 @ 2 Ohm
450W x 1 @ 4 Ohm
Was pushing my 12" kicker L7, 750 watts rms 1500 peak.
pounded good for couple of months.
one day it started to make wierd sound at low volume. sound ok at high but that didnt last long.
sub dont work and is stiff! anyone know the cause of this. is the amp too much power for the rms.
sub was wired 2ohm to the 1ohm stable load!
any suggestions?
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7440
your making no sense lol
even at 900rms @ 2ohm it is over the limit for the l7
and at 1ohm .. its well over the limit..
if you know what your doing you might be fine over-powering that sub IF the enclosure is built to specs and it is a clean unclipped signal.. and you don't abuse the setup trying to make it do something it was not designed to do
you have a nice amp.. time to get a nice sub
Username: West_21
Amarillo, Tx
lol, i got you. i just got a good deal on the sub from a friend and just plugged and played. mistake. wat sub best fits that amp? or subs? in your opinion. thx for response.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7442
depends on the budget/goal
Username: West_21
Amarillo, Tx
money aint a thing really just time consuming. need to know wat setup would be good for the amp. dnt want to blow any more subs.lol
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7444
you need to post a budget and what you want.. sq/sql/spl
we can suggest a sub that surely you will not be willing to pay for
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7445
also need to know vehicle.. what kind of box room you have..
10s/12s/15s
Username: Joebruce
TC Sounds/DLS
Post Number: 2933
"money aint a thing"
lol everyone always says that! Ok big balla here get 4 of these
http://icondealerservice.com/catalog/index.php?_a=viewProd&productId=25
Username: West_21
Amarillo, Tx
srry.
its a 2000 mazda tribute. daily driver.
box room is 48"L 18" H
12s
$$$150 to 200 per sub
SQ
Username: West_21
Amarillo, Tx
haha good one twizt.. my bad. lmao.
amp cant even handle that sucka.
Username: Joebruce
TC Sounds/DLS
Post Number: 2934
No personal experience with these subs but I always heard great things about them
http://www.sonicelectronix.com/item_12257_JBL+P1222.html
2 dual 2ohm wire it to a final 2ohm 450wrms per sub
Or
http://www.woofersetc.com/p2519/G5124--Boston-Acoustics-12"-450-Watt-Single-4Ohm-Subwoofer.htm
^Compared to JLw6 but a bit better
Username: Joebruce
TC Sounds/DLS
Post Number: 2935
Actually these would be perfect!
http://cgi.ebay.com/2-RESONANT-ENGINEERING-SE12-D4-SE12D4-SE-12D4-RE-AUDIO_W0QQi temZ200395207133QQcmdZViewItemQQptZCar_Subwoofers_Enclosures?hash=item2ea87c31dd
Username: Skdooley
Roanoke, VA
Usa
Post Number: 40
x2 on the Re SE's. Should be a great match. Did you have the gain set correctly on the amp? That could have been part of the problem for the blown sub.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7446
x3 on the RE SEs.. I run them sealed in my SQ car
Username: West_21
Amarillo, Tx
RE NICE..
2 them are good with that amp. how would it split the power.. dnt kno much bout this stuff
Username: West_21
Amarillo, Tx
Post Number: 7
prob not.. was no more than half way shawn
Username: Philly306
If youre going to give...
Post Number: 1474
"sub was wired 2ohm to the 1ohm stable load!"
Not trying to embarrass you but this is fûcking priceless.
Username: West_21
Amarillo, Tx
Post Number: 8
are u sayin to get one of these or 2? will they not be underpowered..
Username: West_21
Amarillo, Tx
Post Number: 9
yo my bad.. i didnt see the 1200( per pair)
thx fellas!! helped me out alot..
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7447
600rms each.. you need two.. that amp will do 1300-1400rms @ 14.4v @ 1 ohm
its a perfect match
Username: West_21
Amarillo, Tx
Post Number: 10
cool man. lotta help.. and i would use this diagram on top?
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=2&woofer_imp=4
Username: West_21
Amarillo, Tx
Post Number: 11
yo, other than them RE's,
wat do ya think bout 2 10's cvx?
600 rms / sub. or are the RE better? and if so, in wat way???/
Username: Joebruce
TC Sounds/DLS
Post Number: 2937
RE > Keeker
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Subwoofers > Why did my voice coils blow??? [ « Previous ] [ Next » ]
