Thread: Ot:: looking for hdmi cables good for 1080p transmission |
Platinum Member Username: Insearchofbass
York,
Pennsylvania
Post Number: 12835 Registered: Jun-04
| Posted on Saturday, October 31, 2009 - 06:37 pm: |
as title states |
Platinum Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 10702 Registered: Jul-06
| Posted on Saturday, October 31, 2009 - 07:10 pm: |
So what is the question?... The HDMI standard supports up to 1080p res so any hdmi cable should work |
York,
Pennsylvania
Post Number: 12836 Registered: Jun-04
| Posted on Saturday, October 31, 2009 - 07:33 pm: |
apparently version 1.3 supports 1080p |
Gold Member Username: Snowball123
West Allis,
WI
Post Number: 3283 Registered: Oct-07
| Posted on Saturday, October 31, 2009 - 08:21 pm: |
just get some cheap ones on Amazon. Don't fall for the more you pay for the better quality picture you get. I bought 10 dollar ones off Amazon and they are quite nice and very durable. |
Diamond Member Username: Wingmanalive
Www.stainles...
.ecrater.com
Post Number: 21545 Registered: Jun-06
| Posted on Saturday, October 31, 2009 - 08:30 pm: |
They HAVE indeed come down drastically in price over the last couple years. I remember ppl paying $60+ for a set. Sad. |
Gold Member Username: Tejcurrent
Post Number: 2002 Registered: Apr-07
| Posted on Saturday, October 31, 2009 - 09:58 pm: |
Yeah, I bought a 100+ dollar set, and got another for free. I have a cantilever mount so I swivel the TV often, the first week the expensive cables stopped working - the end just came loose and fell off. I returned it, hooked up the free set (like $10-15 at radio shack) and had just as good a picture. |
Bronze Member Username: Gcs8
Atlanta,
Ga
Post Number: 81 Registered: Sep-09
| Posted on Sunday, November 01, 2009 - 12:06 am: |
its a digital signal it dosent matter as long as the signal gets there. look on http://www.monoprice.com/home/index.asp there cheep. i got a 24' cable 2 years a go for 18$. |
Philadelphia,
PA
Post Number: 10706 Registered: Jul-06
| Posted on Sunday, November 01, 2009 - 01:42 am: |
Still any cable should work. And yea price has come way down, I bought a $50 cable back when i first got my xbox 360. |
York,
Pennsylvania
Post Number: 12837 Registered: Jun-04
| Posted on Sunday, November 01, 2009 - 02:19 am: |
just under 7 dollars shipped here for a 10 foot http://www.firefold.com/HDMI-Cables-C1278.aspx?gclid=CKj016We6Z0CFchn5QodA37BLg |
Platinum Member Username: Rovin
1 15 = 152.5 DBs ... Trinidad & T...
Post Number: 15603 Registered: Jul-05
| Posted on Sunday, November 01, 2009 - 10:46 am: |
^whoa thats pretty cheap ... |
