Home > Message Board > Car Audio > Subwoofers > Infrasonic Filter
Author Thread: Infrasonic Filter
Username: Skdooley
Roanoke, VA
Usa
Post Number: 24
Is it a bad thing to have the infrasonic filter turned off when the sub is in a ported enclosure? I have a 500/1 on a 12 w7 and to me it sounds better turned off. With it on, it's as if I'm missing certain tones. The sub is only getting half of what it is capable of handling so I'm thinking having the filter off isn't as bad as if I was running 1000 rms to it. If the filter should be on, what should the setting be at? It has Q, Center Freq and Infrasonic Freq. The gain is set correctly according to the manual.
Username: Nd4spd18
Philadelphia, PA
Post Number: 10704
It should be set a bit lower than the tuning of your box. Without it you risk damaging the sub as with a ported box the enclosure does not control the speaker below the tuning frequency. If the sub were to play notes lower you risk overexcursion.
Username: Ericmb
Waycross, Georgia
United States
Post Number: 257
and over excursion will fry yo CHIT!! i would use it no matter what..
Username: Nd4spd18
Philadelphia, PA
Post Number: 10714
Well actually it would be more like break yo chit.... overexcursion is physical damage to the soft parts, not fry the coils.
Username: Skdooley
Roanoke, VA
Usa
Post Number: 31
I've got a new box on the way, when it comes in I'll try to get everything set correctly so I don't damage anything. My sub really doesnt have a whole lot of excursion though. I had a 13 w7 a couple years back and it flexed like crazy. The 12 w7 I have now I guess doesn't have enough power going to it to make it move a whole lot. It still sounds good though.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Subwoofers > Infrasonic Filter [ « Previous ] [ Next » ]
