Thread: Q or BL for for daly driver? |
Bronze Member Username: Gcs8
Atlanta,
Ga
Post Number: 75 Registered: Sep-09
| Posted on Friday, October 30, 2009 - 09:22 pm: |
should i get the fi Q or BL for daily use in a small ish car. and any recommendations on options? |
Silver Member Username: Denim
SoundSolutionsAudio.com,
MD
Post Number: 882 Registered: Nov-06
| Posted on Saturday, October 31, 2009 - 12:40 am: |
What are your goals? Both can be ran daily, but they are designed with different goals in mind. |
Atlanta,
Ga
Post Number: 78 Registered: Sep-09
| Posted on Saturday, October 31, 2009 - 03:26 pm: |
sql in the back of a Camry. |
Gold Member Username: Dustin3
D&L Audio Tech. Dustin
Post Number: 5159 Registered: Oct-05
| Posted on Saturday, October 31, 2009 - 04:02 pm: |
get the q charles. |
Gold Member Username: Mendonmafia
Post Number: 1849 Registered: Aug-06
| Posted on Saturday, October 31, 2009 - 05:16 pm: |
everyone is gonna tell you to get the q over here cuz its a good sq sub that gets loud. i say get the bl cuz its more efficient and you can get a flat wind which will drop the fs a bit, increase power handling and increase efficiency also the hyperpole will help the power handling as well. theres other options to further increase power handling but i believe they drop the efficiency. |
Gold Member Username: Drant19
DUB-C,
TX
Post Number: 2124 Registered: Aug-07
| Posted on Saturday, October 31, 2009 - 06:12 pm: |
yea but i doubt that camry alt couldnt handle much more than 1krms |
Platinum Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 10701 Registered: Jul-06
| Posted on Saturday, October 31, 2009 - 07:07 pm: |
The Q in the proper enclosure, with a 1000w amp = awesomeness. For the enclosure, sealed or low tuned ported. I run two 10" Qs sealed myself and it is the best sounding system I've ever had. Output won't win SPL comps but its plenty loud enough for a daily driver. |
Atlanta,
Ga
Post Number: 79 Registered: Sep-09
| Posted on Saturday, October 31, 2009 - 07:43 pm: |
think my amp puts out 1200Wrms on a good day |
Gold Member Username: Somedonniedude
Illinois
Braaap MX
Post Number: 2804 Registered: May-07
| Posted on Sunday, November 01, 2009 - 12:19 am: |
What kind of music do you listen to? what amp do you have? do you plan on getting a proper custom box, or using a prefab? I wouln't get the BL if you plan on going sealed, just throwing that out there (never had a q or a bl though) |
Post Number: 1850 Registered: Aug-06
| Posted on Monday, November 02, 2009 - 12:10 am: |
if you go sealed definitely dont get the bl, its designed fro ported. |
