Thread: Alpine mrp-m1000 amp? |
New member Username: Nick89
Post Number: 1 Registered: Oct-09
| Posted on Thursday, October 29, 2009 - 10:44 pm: |
ok guys, i have 2 audiobahn aw150t's and i'm wondering if the alpine mrp-m1000 amp will be the right choice. The subs handle 600rms a piece with a single 4ohm operation, while the amp puts out 600w rms x 1 at 4 ohms, and 1000w rms x 1 at 2 ohms. The amp is a mono amplifier, so i could just be retarded when it comes to this stuff. But any suggestions will be greatly appreciated. Thanks. |
Silver Member Username: Wackzirth88
K-town,
Il
U.S.
Post Number: 173 Registered: May-09
| Posted on Friday, October 30, 2009 - 09:04 pm: |
since there single 4 ohms. u can wire them together parallel and make it 2 ohms.if u dont kno how to wire them check this out http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=41 that amp will work great with ur subs, how much is it goin to cost? there may be better options out there |
Post Number: 2 Registered: Oct-09
| Posted on Saturday, October 31, 2009 - 02:49 am: |
i already have the subs. the amp is gonna run around 270. and that website was very helpful. i appreciate the help. but if you know of anything better as far as the amp goes for a more reasonable price please let me know. |
Platinum Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 10709 Registered: Jul-06
| Posted on Sunday, November 01, 2009 - 01:49 am: |
That amp will work with those subs, and alpine makes good quality amplifiers, so yes good choice. |
Bronze Member Username: Skdooley
Roanoke,
VA
Usa
Post Number: 51 Registered: Oct-09
| Posted on Thursday, November 05, 2009 - 10:48 am: |
I'd say exchange those Audiobahn for some type R's. Get dual 2 ohms so you can run them to the amp at 2 ohms at 1000 rms and they'll sound good. You'd have matching brands and better quality subs. |
Philadelphia,
PA
Post Number: 10728 Registered: Jul-06
| Posted on Saturday, November 07, 2009 - 07:24 am: |
There are a whole lot of better choices for subs, not hard at all to get better than audioburn, but he said he already has those |
K-town,
Il
U.S.
Post Number: 185 Registered: May-09
| Posted on Monday, November 09, 2009 - 10:46 pm: |
yea he needed an amp suggestion |
New member Username: Heba66
United States
Post Number: 2 Registered: Nov-09
| Posted on Tuesday, November 17, 2009 - 03:43 pm: |
Do you need any help on Electronics Engineering or anything? Are you looking for some extraordinary Mechanical Engineers ? Do not worry just visit Freelancer.com . There are thousands of coders are waiting for you. They are very experienced and very cheap. Use this 'TURBOCIRCUITS' coupon word to get some extra opportunity. Have a nice time bye |
