Thread: Every audiphiles...."not" dream |
Silver Member Username: Bakerj72
Regina,
Saskatchewan
Post Number: 189 Registered: Jun-05
| Posted on Thursday, October 29, 2009 - 04:08 pm: |
ill keep it short 400-700$ budget need new HU and speakers(possible amp) need headunit with decent ipod interface 2000integra speaker upgrade 6.5 componet up front and coax in the back 1) should i even bother with rear speakers? just amp the the front and leave the rear empty? 2) if i amp the front channel will the HU amp transfer power to the back speakers? (ie 18wrmsx4 => 36wrmsx2)? 3)to get bass is it worth looking into 6.5" "sub drivers for the rear ? i am willing to buy used and off the net including ebay..... thanks for your time just pretend im your clueless girlfriend that likes a lil bass and ur building her a system.... but anything past building me a system and ur gunna run into some problems :P |
Silver Member Username: Exige
CDT, Audiopulse Dealer
Post Number: 824 Registered: Nov-07
| Posted on Thursday, October 29, 2009 - 04:37 pm: |
Don't bother with rear speakers. Spend the money on an amp. HU will not transfer power as you suggest. If you want something that's going to sound decent, look for a real subwoofer...not 6.5's Make it easy for yourself: New HU, 4-channel amp, front components, one sub. Run the components off the front two channels, bridge the back 2 channels for your sub. |
Gold Member Username: Livin_loud
COD4 Addict
Post Number: 2957 Registered: Jan-06
| Posted on Thursday, October 29, 2009 - 05:15 pm: |
if you want some bass a nice 8" or two should do the trick. don't bother with rear fill unless you really want to blow more money. Exige pretty much gave you the blueprints to follow. get a real nice set of components up front, a decent HU, a little bass for the rear and spend the rest on the amp. |
Silver Member Username: Boomtank
Rochester,
NY
Post Number: 656 Registered: Oct-06
| Posted on Thursday, October 29, 2009 - 06:19 pm: |
If you don't want lound bass, you could get a nice set of midbass speakers for the rear and good components for the highs up front all run on a 4-channel amplifier. $20 - 8 or 4 gauge wiring kit $150 - Headunit ( Pioneer Premier DEH-P410UB ) $235 - decent amp ( Rockford Punch P400-4 ) $170 - comp. speakers ( MB Quart PVI 216 ) $135 - midbass (MB Quart PVI 164) |
Regina,
Saskatchewan
Post Number: 190 Registered: Jun-05
| Posted on Thursday, October 29, 2009 - 07:04 pm: |
ive wired subs to my trunk before but if i choose to amplify my front for a 2000 integra do i just put the amp in the trunk again or should i find a place up front... any suggestions? |
Rochester,
NY
Post Number: 657 Registered: Oct-06
| Posted on Thursday, October 29, 2009 - 07:10 pm: |
If you can fit it under one of your front seats it would save amount of wire used, or run it to the trunk ( which is less wire for the rear speakers ) |
Regina,
Saskatchewan
Post Number: 191 Registered: Jun-05
| Posted on Thursday, October 29, 2009 - 07:45 pm: |
i want a good HU that has solid ipod interface somewhere in the 200-300 price bracket double dinns work too and since im not gunna be using the HU's mosfet it doesnt need a on board amp(highly doubt thats avoidable these days) and sub 14wrms is fine since im not using it any suggestions? |
COD4 Addict
Post Number: 2959 Registered: Jan-06
| Posted on Thursday, October 29, 2009 - 08:29 pm: |
http://signature.crutchfield.com/s_113KDCX693/Kenwood-Excelon-KDC-X693.html?show All=Y&tp=5684 http://signature.crutchfield.com/s_105KDA805/JVC-Arsenal-KD-A805.html?showAll=Y& tp=5684 http://signature.crutchfield.com/s_130P510UB/Pioneer-Premier-DEH-P510UB.html?sho wAll=Y&tp=5684 |
Rochester,
NY
Post Number: 660 Registered: Oct-06
| Posted on Thursday, October 29, 2009 - 08:34 pm: |
The pioneer premier 510UB and 410UB are both great headunits. USB and IPod direct hookup. Very nice to have. I use the 510UB and use an 8GB USB Flash Drive. My friend loves his 410UB and only uses his iPod, very good quality out of those units. Why spend 300 of your 700 on a head unit when you dont need too? 400 for speakers and 4-channel is gonna give you not so good quilty stuff. |
Silver Member Username: Jbpitt
Pittsburgh,
Pa.
Usa
Post Number: 162 Registered: Jul-09
| Posted on Thursday, October 29, 2009 - 08:35 pm: |
I have this one, an its been a solid hu. http://www.sonicelectronix.com/item_11763_Kenwood+eXcelon+KDC-X792.html |
Silver Member Username: Ericmb
Waycross,
Georgia
United States
Post Number: 254 Registered: Nov-08
| Posted on Thursday, October 29, 2009 - 08:40 pm: |
i have that same kenwood... great headunit! |
Gold Member Username: Hittin1
TEAM REVOLUTION,
La.
Lake Charles...
Post Number: 4065 Registered: May-07
| Posted on Thursday, October 29, 2009 - 09:13 pm: |
I 2nd the Kenwood w/ usb.. I won';t use anything but usb.. I would stay away from the MB Quartz setup as recommended earlier.. Much better products available for same or less prices... |
Regina,
Saskatchewan
Post Number: 192 Registered: Jun-05
| Posted on Friday, October 30, 2009 - 01:47 am: |
if not MB Q's then which components? |
Gold Member Username: The_image_dynamic
San Diego, California
Post Number: 5400 Registered: Dec-06
| Posted on Friday, October 30, 2009 - 02:05 am: |
http://www.sonicelectronix.com/item_10493_DLS+Reference+R6A.html http://www.sonicelectronix.com/item_9128_JBL+C608GTi-mkII.html |
Regina,
Saskatchewan
Post Number: 193 Registered: Jun-05
| Posted on Friday, October 30, 2009 - 01:45 pm: |
these speakers http://cgi.ebay.ca/NEW-BOSTON-SL60-6-5-6-1-2-220w-COMPONENT-CAR-SPEAKERS_W0QQite mZ300347827606QQcmdZViewItemQQptZCar_Speakers?hash=item45ee202596 this amp http://cgi.ebay.ca/Alpine-MRV-F307-4ch-50-watts-x-4-bridgeable-V12-Amp_W0QQitemZ 160370227457QQcmdZViewItemQQptZCar_Amplifiers?hash=item2556cf7901 smart? |
Regina,
Saskatchewan
Post Number: 194 Registered: Jun-05
| Posted on Friday, October 30, 2009 - 01:47 pm: |
keep in mind there will be no rear speakers |
Silver Member Username: M0nstar
Toledo,
OH
U.S.
Post Number: 376 Registered: Dec-08
| Posted on Friday, October 30, 2009 - 03:39 pm: |
DUDE IF I WERE YOU I WOULD TOTALLY GET THOSE JBLs THAT BRAD SUGGESTED! those look soooo sweet! the grill surrounding the cone but leaving the tweet out looks awesome, and then for flush mount all you do is screw the houseing in trim??? most useful and easy to install sets ive ever seen. |
Post Number: 828 Registered: Nov-07
| Posted on Friday, October 30, 2009 - 06:13 pm: |
^lol. |
TEAM REVOLUTION,
La.
Lake Charles...
Post Number: 4070 Registered: May-07
| Posted on Friday, October 30, 2009 - 07:06 pm: |
It's Lucas... Let him revel in what's new....... to him.. lol They are sweet though... |
