Home > Message Board > Car Audio > Head Units > Clarion RD1 Code Needed
Author Thread: Clarion RD1 Code Needed
Username: Lperks69
Chippenham, Wiltshire
Uk
Ive recently taken my battery off to change it but didnt realise the code was missing i would be very greatful if any one could help
Clarion rd1
model: PU-2325A
S/N CL0410X0012302
Many Thanks in advance
Username: Regrooster
Post Number: 2157
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
Here is a link showing an example of CLARION BARCODE SERIAL NUMBER label,
(ignore the Davidson Electronics watermark)
http://www.davidsonelectronics.co.uk/images/Serial_Locate/ClarionBarcode.jpg
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Head Units > Clarion RD1 Code Needed [ « Previous ] [ Next » ]
