Thread: Sub Re-Cone? |
Silver Member Username: Noob101
Taylorsville,
Utah
Post Number: 191 Registered: Jul-07
| Posted on Tuesday, October 27, 2009 - 02:44 am: |
I need to buy a re-cone for my 12" Fi Q and had a few questions. First, How difficult is it to re-cone a sub? Second, could i buy the re-cone WITH the BP Power option even though my current one doesn't have it? Could it run with the BP power option with my ed.nine.1 amp or would i need new amp,wiring, or anything? |
Silver Member Username: Denim
SoundSolutionsAudio.com,
MD
Post Number: 879 Registered: Nov-06
| Posted on Tuesday, October 27, 2009 - 12:09 pm: |
If you have never re-coned a sub woofer, I would suggest sending it into Fi to do it for you. recone @ ficaraudio.com |
Silver Member Username: Domenico
Glendale,
AZ
Post Number: 135 Registered: Apr-09
| Posted on Tuesday, October 27, 2009 - 01:05 pm: |
you could always try yrself, wouldnt hurt to learn. |
Gold Member Username: Drant19
DUB-C,
TX
Post Number: 2104 Registered: Aug-07
| Posted on Tuesday, October 27, 2009 - 02:36 pm: |
i would only try it myself if i had a spare that was in working condition. otherwise, why screw up a quality woofer when sending it in while most likely yield a better outcome.. just throwin that out there |
Taylorsville,
Utah
Post Number: 194 Registered: Jul-07
| Posted on Tuesday, October 27, 2009 - 03:01 pm: |
Thanks for the advice. I'll contact Fi and may send it in. Anyone have an idea on the BP power option though? |
Glendale,
AZ
Post Number: 140 Registered: Apr-09
| Posted on Tuesday, October 27, 2009 - 03:19 pm: |
when you call fi they will know. |
