Thread: Componets for a PDX 4.150 |
Silver Member Username: Domenico
Glendale,
AZ
Post Number: 131 Registered: Apr-09
| Posted on Monday, October 26, 2009 - 03:04 pm: |
I need a set of componets that would go with a PDX 4.150, i have a PDX 1000 with two 12'' Type R's ina GMC S15 ext cab. My budget is flexable, i would like to keep it under a few hundred bucks cause i still have to buy the amp. I was thinking about the type r/x comps? i can get the type r's for like 100 bones on ebay. anyone have a history with them? (i woulda posted this in the speakers form but its just too slow over there.) |
Platinum Member Username: Rovin
1 15 = 152.5 DBs ... Trinidad & T...
Post Number: 15583 Registered: Jul-05
| Posted on Monday, October 26, 2009 - 07:56 pm: |
thats a 4chan amp so are u going to use it as chan 1 & 2 for comps (3 & 4 for something else) or by bridging chans 1&2 then 3&4 ..which = 300wrms x 2 .... |
Post Number: 15584 Registered: Jul-05
| Posted on Monday, October 26, 2009 - 07:58 pm: |
have head the type R comps & they sound pretty decent if ur going to be using 1 pair of comps y not get the 2.150 2channel amp ... |
Gold Member Username: Joebruce
TC Sounds/DLS
Post Number: 2918 Registered: May-04
| Posted on Monday, October 26, 2009 - 08:32 pm: |
http://cgi.ebay.com/NEW-2009-DLS-UP6I-2-Way-6-5-Component-System_W0QQitemZ360200754812QQcmdZViewItemQQptZCar_Speakers?hash=item53dda3567c Run them active  |
Glendale,
AZ
Post Number: 133 Registered: Apr-09
| Posted on Monday, October 26, 2009 - 10:27 pm: |
i was going to use that for the 2 channels then run two speakers for the rear pannels in my truck. |
Gold Member Username: Snowball123
West Allis,
WI
Post Number: 3259 Registered: Oct-07
| Posted on Monday, October 26, 2009 - 10:59 pm: |
Can I has the PDX? |
TC Sounds/DLS
Post Number: 2920 Registered: May-04
| Posted on Monday, October 26, 2009 - 11:05 pm: |
Rear speakers in a ex cab truck? Thats pointless,just like the dash 4x6 speakers that were in my S10 ex cab. Im only running one set of comps,DLS MS6A,in there and its way more than enough. I say go with my idea,run the DLS active FTW! |
Post Number: 15586 Registered: Jul-05
| Posted on Monday, October 26, 2009 - 11:23 pm: |
those MS6 sound really good ... |
TC Sounds/DLS
Post Number: 2924 Registered: May-04
| Posted on Monday, October 26, 2009 - 11:27 pm: |
Yes,yes they do Rovin  |
Gold Member Username: Basebalz13
Moneta,
Va
Usa
Post Number: 1876 Registered: Aug-07
| Posted on Tuesday, October 27, 2009 - 01:30 pm: |
i can sell you a nice CDT CL-62 carbon fiber mids ;) http://www.vertexaudio.com/store/pc/CDT-Audio-CL-62CF-6-5-Carbon-Fiber-Component -Set-30p169.htm that set right there |
Glendale,
AZ
Post Number: 138 Registered: Apr-09
| Posted on Tuesday, October 27, 2009 - 02:31 pm: |
yea rovin i think im going to go with the type r comps and a pdx 2.150, im not THAT into comps so the type r comps should be fine, thanks for alll the advice guys : |
