Home > Message Board > Car Audio > Subwoofers > Archive through November 02, 2009 > Hifonics vs Boss Diablo
Author Thread: Hifonics vs Boss Diablo
Username: Cory51191
I have a Fusion 2000watt amp (PP-AM200010). I wanna get 4 Hifonics (HFi-12D4) 12" 600watt subwoofers. Or 2 Boss Diablo (D12F) 12" 1000watt subs. Would either of these be a good setup on that amp? How should i wire the subwoofers to the amp if i do the 4 HFIs? (this is how i have the subwoofers wired now: http://i188.photobucket.com/albums/z179/cormaster13/wired.jpg)
I have a 4 gauge power supply wired to the amp on an 80watt fuse at the terminal and 4 25watt fuses in the amp.
The 4 subs that are currently hooked up to the amp are wired to the amp with speaker-wire (not sure on the gauge but its a tiny bit thicker than basic speaker wire). What guage should i get for the new Hifonics or Boss subs?
Username: Texas_bass
Houston, TX
Post Number: 701
i would go with 2 cerwin vegas vmax there 100rms and even when there not given full power they hit im running a 10 and it does really nice check them out
http://www.sonicelectronix.com/item_12860_Cerwin-Vega+V-Max124.html
Username: Cory51191
Post Number: 7
100rms? that amp would blow those badly. i also have 2 10" 300rms and it blew them. i think if i went with either the 4 HFi's or the 2 Diablo's the amp would split the power up better. right?
Houston, TX
Post Number: 702
sorry typo 1000rms lol
Username: Cory51191
Post Number: 8
the subs in the link you posted are 500 watt rms. thats what those Diablo's are but i can get them for $50 each online and $70 each from someone who sells them where i live.
here are the Boss Diablo's from the same website.
http://www.sonicelectronix.com/item_12273_Boss+D12F.html
Houston, TX
Post Number: 704
500 rms each voice coil there dual coil
Houston, TX
Post Number: 705
im running mine off a hifonics brutis 2005d amp @ 2ohms and the gain is turn down quiet a bit but i got mine in a box tuned to 33hz
Username: Cory51191
Post Number: 9
how do you know what your box is tuned to? by the dials on the amp? is there something i could read about to learn how to tune a box?
Username: Cory51191
Post Number: 10
are these subs any good?
http://www.buy.com/prod/pyle-pld-12wd-dryver-subwoofer-3200w-pmpo-pyle-pld-12wd- dryver/q/loc/111/202757445.html
Houston, TX
Post Number: 706
by the specs of the speaker and there is alot of places u can find that will help u design a box and tune it then you build the box after that to the secs the program shows you there alot more than these 2 but dont know them off the top of my head and have u done any elc. upgrades???
http://www.the12volt.com/info/diagrams.asp
here is another one
http://reaudio.com/speaker_box/LPort_Box_Calc.html
Houston, TX
Post Number: 709
heres some more on this forum
http://forum.ecoustics.com/bbs/messages/4/590151.html
Username: Cory51191
Post Number: 11
"L" ported is good?
Username: Basebalz13
Moneta, Va
Usa
Post Number: 1862
its fine as long as theres enough port area
Username: Cory51191
Post Number: 14
i'll just stick with the box i have. thanks 4 your help guys but no1 really helped me with my options on subwoofers. i'd appriceate it if someone could. thank u
Username: Dangeranger
Fredericktown, Ohio
United States
Post Number: 162
stay away from boss and those hifonics subs. What's your budget and what kind of sound are you going for? do you want loud or sound quality or both? Also how much space do you have to work with? what type of vehicle.
The amp you have is 1000 rms at 1 ohm. RMS is the power ratings you want to look at, not max.
Fredericktown, Ohio
United States
Post Number: 163
also for your subs 12 gauge speaker wire will be fine.
Username: Cory51191
Post Number: 15
i have 4 gauge speaker wire so it will be fine.
i have plenty of room, i'm working with an expedition. but i plan on moving the system to an eclipse one day so i should be wise about that.
i don't wanna really spend more than 150 on a sub because i need to get a cap too. i wanna get 2 12''s because i already have a nice box with 2 12" holes.
Username: Boomtank
Rochester, NY
Post Number: 654
I doubt you could fit 4 gauge wire into a speaker terminal. You have 4 gauge power wire to your amplifier from your vehicle's battery.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7408
$150 per sub? And you don't need a cap.
Pics of said box?
All those you listed = fail.
Username: Joebruce
TC Sounds/DLS
Post Number: 2919
Help this dude out guys. This thread is packed with fail!
"i need to get a cap too"
No you dont.
"i wanna get 2 12''s because i already have a nice box with 2 12" holes."
Box should be built to subs specs.
BTW that amp is only rated @ 1000wrms @ 1ohm. Im not familiar with Fusion amps so I dont know if they do rated or are underrated or what.
I would get 2 of these
http://www.audioque.com/aq/SDC2_5_Series.htm
$139 each and build a new box for them tuned to 34-40hz and call it a day.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7411
Or since a new box will be involved.. a single 15" rated 1000rms
Username: Drant19
DUB-C, TX
Post Number: 2103
4 gauge speaker wire? WTF??!
you will be fine with 12gauge at MOST. even that is overkill with the amount of power talked about in this thread..
what do you want? and whats your budget for it?
Username: Skdooley
Roanoke, VA
Usa
Post Number: 23
I second the AQ subs and say go with an ED nine.1 for 195 shipped.
Username: Wackzirth88
K-town, Il
U.S.
Post Number: 171
3x on the aq subs, or look for deals on re se subs. i believe u want to be bumpin sometime before december/jan. so pass on the ed nine.1.
Username: Domenico
Glendale, AZ
Post Number: 152
AQ subs x100
Home > Message Board > Car Audio > Subwoofers > Archive through November 02, 2009 > Hifonics vs Boss Diablo [ « Previous ] [ Next » ]
