Home > Message Board > Car Audio > Head Units > Peugeot 206 Philips radio code
Author Thread: Peugeot 206 Philips radio code
Username: P2l1234
Hey, im looking for a radio code for my car
Its from a peugeot 206
Its a philips 22RC200/65S
and the serial number is FD0100340051747
If anyone could get me the code i'd be most grateful
Thanks!
Username: Regrooster
Post Number: 2140
Insufficient information
The radio will have to be removed from the car dashboard .
Then please quote ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number beginning with RG or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
Username: P2l1234
Ive got it here in my hand so here goes:
22RC200/65s
T0Y475
FD0100340051747
029018
E2
PHAPMFY0051747
REF.PEUGEOT:
96 415 230 8000
PHM0051747
thats every single number on it
Thanks for the help so far!!
Post Number: 2144
Gareth
Username: P2l1234
Registered: Oct-09 Posted on Sunday, October 25, 2009 - 08:00 pm:
22RC200/65s
T0Y475
FD0100340051747
029018
E2
PHAPMFY0051747
REF.PEUGEOT:
96 415 230 8000
PHM0051747
Sorry...not in my database
Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Head Units > Peugeot 206 Philips radio code [ « Previous ] [ Next » ]
