Thread: 2 amps for jl w6's |
New member Username: Tremor2002
Post Number: 1 Registered: Oct-09
| Posted on Sunday, October 25, 2009 - 04:54 pm: |
is it ok to run 2 amps for each sub on my jl w6's 1 amp is a spl 1600 and the other is a 100 nitro please help me get these things rocking |
Post Number: 2 Registered: Oct-09
| Posted on Sunday, October 25, 2009 - 04:55 pm: |
1000 nitro i mean |
New member Username: Imagedynamics214
Dallas,
Tx
Post Number: 2 Registered: Nov-09
| Posted on Wednesday, November 04, 2009 - 12:47 am: |
those amps are shitty. get a jl audio 1000/1 and power both of them at 2 ohms, if they 4 ohms a piece |
Bronze Member Username: Skdooley
Roanoke,
VA
Usa
Post Number: 50 Registered: Oct-09
| Posted on Thursday, November 05, 2009 - 10:44 am: |
the 1000/1 is the solid choice, if you don't want to spend that much though, get the AQ1200D and run them at 1 ohm. They'll get 600 rms a piece and be happy. What kind of box are they going in? If you need a good one, there are a few guys on the forum who can make you one. Bassman3 is one for example. Your encloure is as important as the power they are receiving. |
