Home > Message Board > Car Audio > Subwoofers > Archive through November 02, 2009 > Finaly got some HID lights
Author Thread: Finaly got some HID lights
Username: Deadrabit
Marionville, MO
Post Number: 2153
ordered from DDM some 6k and 10k... when i got them i got 6k and 3k or something very yellow,
just my luck they sent a yucky color
Username: Ericmb
Waycross, Georgia
United States
Post Number: 232
dang.. HID's look really good.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7395
use the 3k for fogs..
Username: Basebalz13
Moneta, Va
Usa
Post Number: 1868
no one cares. are you doing show car stuff now? haha
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7404
if you fail at one thing.. move on to the next failure
Username: Jtown
Texas
Post Number: 3953
hopefully your not an idiot and at least got projector head lamps....
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7409
thieves ...
you should know the answer to that one
Username: 813thumper
Tampa, FL
United States
Post Number: 130
man you guys are mean.. he may not have listened to you on several occasions but seriously.. lighten up
Username: Philly306
If youre going to give...
Post Number: 1462
you better lighten up guys cuz we all know...
internetisseriousbusiness
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7410
orly
Username: Snowball123
West Allis, WI
Post Number: 3260
and thumper.
you're next.
Username: Deadrabit
Marionville, MO
Post Number: 2154
well i guess i am a big fail.... but for some reason at nationals i got a check and a big trophy that says number one?
Username: Philly306
Post Number: 1464
wow that event looks huge. you must have had some killer competition.
Tampa, FL
United States
Post Number: 131
what do you mean im next
Username: Jtown
Texas
Post Number: 3955
you also got a sheit number for all the money and time you WASTED.
whatever helps you sleep at night, that last comment tells me that you didn't bother to get projectors. Hopefully you won't blind anyone driving the opposite direction of you and cause them to wreck their vehicle.
Tampa, FL
United States
Post Number: 132
i havent wasted any money or time.. do you know what my system is and what i got it for?? and i am extremely happy with the way everything sounds regarding my setup. im not trying to get big numbers..
Username: Jtown
Texas
Post Number: 3956
Are you dumbassBLK?
Moneta, Va
Usa
Post Number: 1875
alama gates handing me my trophy...
Username: Tejcurrent
Post Number: 1986
D- you're my hero.
Sorry to thread jack, but I'm seriously considering getting a HID kit for my Tahoe, can anyone point me in the direction of everything I need and good brands? Everything is stock at the moment and I've never done any upgrades like this before.
I do a lot of driving in the middle of nowhere and it's very difficult to see with stock lights. I would prefer as little color as possible - just white or a hint of blue. Thanks guys.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7412
best thing to do is a retrofit.. and it can get pricey..
but well worth it.. oem quality > aftermarket
Diamond Member
Post Number: 23534
s2k projectors for retrofit ftw. razor cut offs.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7413
tsx and tl projectors are also nice..
or do a bi-xenon with some fx35s..
you can always color mod by spacing the lens.. or modding the cutoff
Post Number: 1987
Any links? I would like to do it nice, but I would like to keep it on a bit of a budget. I will wait to do it right if need be, but I don't know where to start.
Like for instance, I've been searching retro fitting, but I'm having trouble finding information that is clear/concise. Thanks again.
Username: Deadrabit
Marionville, MO
Post Number: 2155
i got mine from ddmtuning.com
works great for me, and good price
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7414
ddm makes cheap kits.. had group buys on the lgt boards.. a lot of people have issues with the kits.. ballasts always going out
i have a ddm 3k for fogs.. no issues but i have a separate wiring harness and relay
troy.. best thing is to check forums for your car and see if anyone offers it
you can do it yourself.. buy a set of projector headlights and swap out projectors.. or mod your stock lights (if they have cleared lenses)
to do so you'd need to read up on some builds.. you can do it many ways
i did a retro on my oem projectors with fx35 projectors..
its on my cardomain - http://www.cardomain.com/ride/3108799
Username: Livin_loud
COD4 Addict
Post Number: 2954
http://store.theretrofitsource.com/
Home > Message Board > Car Audio > Subwoofers > Archive through November 02, 2009 > Finaly got some HID lights [ « Previous ] [ Next » ]
