Thread: HELP WITH WIRING |
New member Username: Cory51191
Post Number: 1 Registered: Oct-09
| Posted on Saturday, October 24, 2009 - 12:44 am: |
I have a Fusion 2000watt amp (PP-AM200010). I wanna get 4 Hifonics (HFi-12D4) 12" subwoofers. Would this be a good setup on that amp? How should i wire the subwoofers to the amp? (this is how i have the subwoofers wired now: http://i188.photobucket.com/albums/z179/cormaster13/wired.jpg) I have a 4 gauge power supply wired to the amp on an 80watt fuse. The 4 subs that are currently hooked up to the amp are wired to the amp with speaker-wire (not sure on the gauge but its a tiny bit thicker than basic speaker wire). What guage should i get for the new 4 Hifonics? |
Silver Member Username: Domenico
Glendale,
AZ
Post Number: 125 Registered: Apr-09
| Posted on Sunday, October 25, 2009 - 11:41 am: |
hifonics is pooop, you should concider a different sub. |
Post Number: 2 Registered: Oct-09
| Posted on Sunday, October 25, 2009 - 02:29 pm: |
i was also thinking of setting up 2 of Boss' Diablo 12" 500 watt rms shallow mounts (D12F). Would this be a better setup on the amp? And what about speaker wire gauge? |
Silver Member Username: Mmaudioconcepts
Post Number: 657 Registered: Jan-07
| Posted on Sunday, October 25, 2009 - 08:13 pm: |
that amp puts out its power at 1 ohm, 4 dual 4ohm subs wont give you that load. |
Post Number: 4 Registered: Oct-09
| Posted on Sunday, October 25, 2009 - 09:59 pm: |
So what would be a good pair of subs? |
