Home > Message Board > Car Audio > Subwoofers > Archive through November 02, 2009 > Subs in s10
Author Thread: Subs in s10
Username: Ryancha
i have a reg cab s10 with a kenwood 12 sub does anyone know any sub with less than 6 in debth than will sound good and rock 2 would be nice
Username: Insearchofbass
York, Pennsylvania
Post Number: 12737
what amp do you have to run the sub?
Username: Ryancha
right now just a kenwood 800 watt
York, Pennsylvania
Post Number: 12745
what model
Username: Ryancha
dont know its ok but doesnt have a cooling fan so it cuts out looking for 1 thaat has a fan
Username: Ryancha
sorry typo its a kac6202
York, Pennsylvania
Post Number: 12748
they are claiming that amp puts out 200 rms at 4 ohms bridged
Features of Kenwood KAC6202:
* 60 watts RMS x 2 at 4 ohms (100 watts x 2 at 2 ohms)
* 200 watts RMS x 1 bridged output at 4 ohms (4 ohm stable in bridged mode)
* variable high-/low-pass filters (50-200 Hz at 12 dB per octave)
* preamp- and speaker-level inputs
* MOSFET power supply
* CEA-2006 compliant
* Tri-way capable (Tri-Way Crossover required)
* fuse rating: 25A x 1
* 10-gauge power and ground leads recommended — wiring and hardware not included with amplifier
* 13-5/8"W x 2-5/16"H x 11-1/4"D
Username: Ryancha
Post Number: 7
good little amp but looking for something around 600-800watts thats small
York, Pennsylvania
Post Number: 12749
http://cgi.ebay.com/KICKER-CVT-124-CAR-12-INCH-SUBWOOFER-SUB-WOOFER-COMPVT_W0QQi temZ390108787964QQcategoryZ18805QQcmdZViewItem
this sub will work with your current amp but you should have a more powerfull amp
York, Pennsylvania
Post Number: 12750
http://cgi.ebay.com/ALPINE-MRP-M500-CLASS-D-AMP-MONO-BLOCK-AMPLIFIER-NEW_W0QQite mZ400080725338QQcmdZViewItemQQptZCar_Amplifiers?hash=item5d26ab655a
this amp
http://cgi.ebay.com/KICKER-CVT12-12-INCH-2-OHM-CAR-SUBWOOFER-SUB-CVT-COMPVT_W0QQ itemZ360194552637QQcategoryZ18805QQcmdZViewItem
this sub
im not sure if youll have enough room to build a box 1.75 cf ported
Username: Ryancha
Post Number: 8
thanks should they have a clean sound
York, Pennsylvania
Post Number: 12751
they arent on the side of sound quality sound more in the middle sql....do you want more on the side of sound quality?
York, Pennsylvania
Post Number: 12752
http://www.stereointegrity.com/
York, Pennsylvania
Post Number: 12753
http://cgi.ebay.com/HIFONICS-ZXi1010-2-CHANNEL-AMPLIFIER-CAR-AMP-ZXi-1010_W0QQit emZ300353601977QQcmdZViewItemQQptZCar_Amplifiers?hash=item45ee7841b9
this amp
Username: Ryancha
Post Number: 9
thats perfect thanks alot i dont care too much about spl have any ideas on 6.5 comp that arent to $$$$$$
York, Pennsylvania
Post Number: 12754
how much are you willing to spend on the comps and what amp will you be using to power them
Username: Ryancha
Post Number: 10
probally the kenwood 4 now and around250
Username: Basebalz13
Moneta, Va
Usa
Post Number: 1852
i can sell you a set of CDT CL-62CF carbon fiber for around that price
http://www.vertexaudio.com/store/pc/CDT-Audio-CL-62CF-6-5-Carbon-Fiber-Component -Set-30p169.htm
that exact same set ^
if you need any ref's just ask in here
Username: Dangeranger
Fredericktown, Ohio
United States
Post Number: 159
Ryan, have you thought about putting buckets in and making a counsel box?
Username: Ryancha
Post Number: 11
the seat part but not the box have any ideas on the seats
Fredericktown, Ohio
United States
Post Number: 160
http://www.facebook.com/album.php?aid=70639&id=513356761&l=02708fc10b
that's how i set my truck up. Is your seat now a bench or a 60/40 split?
York, Pennsylvania
Post Number: 12760
if you can afford 299 for a set heres a pair id recommend. Its cdt's high level. They used to cost 799.99.
http://www.woofersetc.com/p1118/HD62Z--CDT-Audio-High-Definition-65"-2Way-Component-Speakers.htm
Username: Ryancha
Post Number: 12
correct on the 60/40
Fredericktown, Ohio
United States
Post Number: 161
does the counsel box even interest you?
Username: Ryancha
Post Number: 13
yeah i just took a look at yours and that was cool
Username: Ryancha
Post Number: 14
how complicated was the box
York, Pennsylvania
Post Number: 12765
what do you think of the cdt's i recommended? too expensive?
Fredericktown, Ohio
United States
Post Number: 165
i just cut my driver seat down to a bucket, and tied the extra upholstery under the seat, I'm assuming yours is setup similar to mine, but it was a thin piece of plastic or real thin metal and i used a reciprocal saw.
It wasn't too bad. the hard part was making the box.
i think a counsel would be the way to go for you.
Username: Ryancha
Post Number: 15
the cdts could work anything good 4 less
Username: Ryancha
Post Number: 16
can you tell the seat was cut does it still sit well i guess thats how u say it
Fredericktown, Ohio
United States
Post Number: 166
the box took time, but just a lot of test fitting, in the end though it was worth it.
Just measure everything twice and make a template from cardboard etc... it helped a lot.
Username: Ryancha
Post Number: 17
should i discard the dash speakers?
York, Pennsylvania
Post Number: 12766
the hd's are really worth the extra 50 bucks so if you can afford it go with them....youll thank me. the next set id recommend would be 250 but wouldnt be their top of the line.
Username: Ryancha
Post Number: 19
cool thanks adam
York, Pennsylvania
Post Number: 12767
those components are all youll need they have plenty of mid bass and a sweet upper end
Username: Ryancha
Post Number: 20
alright ill thankyou then
Fredericktown, Ohio
United States
Post Number: 167
no problem, if you decide to go that route let me know and i can help you out.
Username: Ryancha
Post Number: 21
any idea about amp 4 them
York, Pennsylvania
Post Number: 12768
you can use the amp you have until you can afford a new one but ill give you an example of what to get
Username: Ryancha
Post Number: 22
adam the only ? i have now is are the subs in sepret chambers? or just 1 the rest i should be able to figure out
Fredericktown, Ohio
United States
Post Number: 168
The same chamber, if you decide to go this route, i'd look into different subs though.
My box is about 1.7 cubes and there was a little room to make it bigger.
York, Pennsylvania
Post Number: 12769
http://millionbuy.net/CarAudio/PowerAmplifier/KIK08ZX350.2/KICKER-08ZX350-2
Fredericktown, Ohio
United States
Post Number: 169
nvm i didn't read up there farther, I'd look into 2 tens. That fit rather snug in my truck, idk how much width you'll have between your seats.
York, Pennsylvania
Post Number: 12770
stick with 1 mag 12 you wont be disappointed
Fredericktown, Ohio
United States
Post Number: 170
i wish i had more room to work with. i envy anyone with a trunk, suv etc... lol
Username: Ryancha
Post Number: 23
you guys r making good suggestions soon ill be spending enough $ to do a good cut through
Username: Ryancha
Post Number: 24
mag 12?
York, Pennsylvania
Post Number: 12771
this
York, Pennsylvania
Post Number: 12778
heres an amp that would work and be cheap
http://forum.ecoustics.com/bbs/messages/4/599665.html
Home > Message Board > Car Audio > Subwoofers > Archive through November 02, 2009 > Subs in s10 [ « Previous ] [ Next » ]
