Thread: fi q 12 on 800 rms fine? |
Bronze Member Username: Rosrock
Post Number: 20 Registered: Mar-09
| Posted on Thursday, October 22, 2009 - 12:57 pm: |
would it be better to get an fi q (1000 rms) or an ascendant audio chaos 12 (800 rms). which one would be better on this power or would they be equal for my mtx 801d? |
Silver Member Username: Denim
SoundSolutionsAudio.com,
MD
Post Number: 876 Registered: Nov-06
| Posted on Saturday, October 24, 2009 - 10:33 am: |
What are your goals? Both drivers will be fine on either amplifier. 200 watts is not going to make much difference. |
Post Number: 21 Registered: Mar-09
| Posted on Saturday, October 24, 2009 - 12:38 pm: |
my goal is pretty obvious.. i want to get the sub that will be most efficient for my amp. |
Gold Member Username: Drant19
DUB-C,
TX
Post Number: 2096 Registered: Aug-07
| Posted on Saturday, October 24, 2009 - 02:46 pm: |
how about, what kind of sound are you looking for?? Denim is absolutely correct when he said that 200 watts wont make much of a difference. |
MD
Post Number: 878 Registered: Nov-06
| Posted on Tuesday, October 27, 2009 - 12:05 pm: |
If your goal was obvious, two people would not be asking you questions to help you find the right direction to go. Are there space limitations that might force you to go sealed? Are you worried about budget between the two? Did you prefer a certain enclosure? Is sheer out put or flat response your preference? etc etc. |
Gold Member Username: Mendonmafia
Post Number: 1832 Registered: Aug-06
| Posted on Tuesday, October 27, 2009 - 04:24 pm: |
if it were me id look for a bigger amp. ive found its nice to have about %50 extra power than your subs need. Keeps things distortion free and will make your subs happy. a lot of subs can take much more than rated power if its clean unclipped power. i ran my infinities kappa perfects at double rated and they absolutely loved it . My 2000 rms alpha loves 3k and my 1000 rms sx liked around 1300. a fiend of mine is even running his shitty pioneers on double rated power, they complain a bit tho but still they suck and they take it. |
Silver Member Username: Domenico
Glendale,
AZ
Post Number: 146 Registered: Apr-09
| Posted on Tuesday, October 27, 2009 - 04:46 pm: |
DP lemmmee geett in thooossee guttttss! ------------ ^x1000 |
DUB-C,
TX
Post Number: 2107 Registered: Aug-07
| Posted on Tuesday, October 27, 2009 - 05:11 pm: |
^^^what? |
MD
Post Number: 880 Registered: Nov-06
| Posted on Saturday, October 31, 2009 - 12:37 am: |
Most sub woofers are ratted at a certain rating for a reason. Running that much more can reach thermal on many drivers. |
Gold Member Username: Somedonniedude
Illinois
Braaap MX
Post Number: 2805 Registered: May-07
| Posted on Sunday, November 01, 2009 - 12:25 am: |
ssd anyone? |
