Thread: New highs |
Silver Member Username: M0nstar
Toledo,
OH
U.S.
Post Number: 357 Registered: Dec-08
| Posted on Wednesday, October 21, 2009 - 01:24 pm: |
im looking for new highs... i have 5 n a quota mounts, not really looking to change it or make pods etc... i cant really find 5.25s that i like everything i find that i want is 6.5 i found these diamond D351, any other suggestions? |
Gold Member Username: Joebruce
TC Sounds/DLS
Post Number: 2898 Registered: May-04
| Posted on Wednesday, October 21, 2009 - 03:08 pm: |
What is your budget? Im on DLS's nuts so Im gonna recommend which ever set you can afford out of these http://www.sonicelectronix.com/viewcat.php?manufacturer_id=210&category_id=73&so rt_order=price_asc Ebay probably has them cheaper though. |
Silver Member Username: 813thumper
Tampa,
FL
United States
Post Number: 117 Registered: Sep-09
| Posted on Wednesday, October 21, 2009 - 04:29 pm: |
always depends on what you wanna spend. Hertz has some pretty awesome speakers that you would be very happy with. Ive heard them in a rather large room and they filled the whole room with ease and sound so clean. They are not harsh either. but depending on how much you wanna spend im not sure which model to recommend.. |
Gold Member Username: Frkkevin
Team DLS SuperNatural...
Post Number: 7378 Registered: Nov-05
| Posted on Wednesday, October 21, 2009 - 06:16 pm: |
i can second DLS  |
Platinum Member Username: Rovin
1 15 = 152.5 DBs ... Trinidad & T...
Post Number: 15577 Registered: Jul-05
| Posted on Wednesday, October 21, 2009 - 08:00 pm: |
3rd for DLS .. |
Toledo,
OH
U.S.
Post Number: 358 Registered: Dec-08
| Posted on Wednesday, October 21, 2009 - 11:20 pm: |
on the DLS C5A series should i amplify both tweeter and midrange off the same channel like ive always done? or is that why im blowing all my tweets? and my budget is about 130 max per set, but ill prolly get the DLS C5's |
Gold Member Username: Big_edge_head
Milwaukee,
WI
Post Number: 4192 Registered: Mar-07
| Posted on Wednesday, October 21, 2009 - 11:28 pm: |
I used to run D3's a couple years ago. They are nice for 100 bucks. Not sure how much they are now though. I still got 'em too. I would go with something else though. The D3's only come with aluminum tweets and they're kinda harsh. I upgraded to HEX's and it was pretty a much night and day difference. |
Tampa,
FL
United States
Post Number: 119 Registered: Sep-09
| Posted on Wednesday, October 21, 2009 - 11:48 pm: |
yeah i still have the diamond d3's in my car waiting for enough bank to grab the Hertz HSK 165's. I got a dealer down here that is going to sell me two sets for only $560 BNIB. They are retail price 800 a set. |
Toledo,
OH
U.S.
Post Number: 359 Registered: Dec-08
| Posted on Thursday, October 22, 2009 - 01:17 am: |
amplify tweeters? yay or nay? |
TC Sounds/DLS
Post Number: 2900 Registered: May-04
| Posted on Thursday, October 22, 2009 - 01:50 am: |
Not sure what you mean but this is how you should hook up components
Unless of course you are running them active but I think its safe to say you are not,no offense. Also you said your budget is $130 per set,how many sets are you planning on getting? I would just buy one good set of comps up front,dont worry about the rear. |
Toledo,
OH
U.S.
Post Number: 361 Registered: Dec-08
| Posted on Friday, October 23, 2009 - 12:00 am: |
^ that diagram is how im doin it. sweet i thought i was doin it right... what is "running them active?" anyways, but when i only have one nice set up front and none in the rear I dont like the way it sounds... its too flat. no surround, unless theres a setting somewhere that would change that.. im in a cherokee so its like if theres no rear sound then its just highs in front and lows in the back and you can clearly tell when sitting anywhere in the car. damn i love car audio. seriously.
TC Sounds/DLS
Post Number: 2903 Registered: May-04
| Posted on Friday, October 23, 2009 - 12:17 am: |
Well if I were you I would buy a nice set of comps for front and throw some decent coax in the rear. Amp the comps for front and just run the coaxs off HU and it should sound fine. |
Toledo,
OH
U.S.
Post Number: 363 Registered: Dec-08
| Posted on Friday, October 23, 2009 - 12:26 pm: |
damn i thought i posted this last night... oh well ill just ask again. would R5 comps be comparible to the MS5 series? |
TC Sounds/DLS
Post Number: 2904 Registered: May-04
| Posted on Friday, October 23, 2009 - 05:58 pm: |
Im not really sure but I would say that the MS5A comps would be a lot different than the R5s. The MS5A uses a completly different tweeter and the mids are made up of different material. I have the MS6A 6.5s and love them. Mid bass is very punchy and tweet is very detailed without being too loud. If you could up your budget a little bit I really think this is a great deal http://cgi.ebay.com/NEW-2009-DLS-UP5I-2-Way-5-25-Component-System_W0QQitemZ18042 3336658QQcmdZViewItemQQptZCar_Speakers?hash=item2a0211a2d2 Or if you could fit 6.5s these http://cgi.ebay.com/NEW-2009-DLS-MS6A-6-5-2-WAY-Components-System_W0QQitemZ15038 2170741QQcmdZViewItemQQptZCar_Speakers?hash=item230379d275 You could also contact tristateaudio on ebay and see if he has any 5.25 MS5A sets that have not been listed. |
Toledo,
OH
U.S.
Post Number: 367 Registered: Dec-08
| Posted on Saturday, October 24, 2009 - 12:03 am: |
Ok so i ordered just the C5A comps at 4:30 because i realized i only have 40w rms to work with and dont have any $ for a new highs amppp =[ on the bright side i still got a set! |
Toledo,
OH
U.S.
Post Number: 374 Registered: Dec-08
| Posted on Thursday, October 29, 2009 - 12:00 pm: |
MAUMEE, OH, US 10/28/2009 12:19 P.M. DESTINATION SCAN MAUMEE, OH, US 10/28/2009 5:31 A.M. ARRIVAL SCAN SYLMAR, CA, US 10/24/2009 1:49 A.M. DEPARTURE SCAN SYLMAR, CA, US 10/23/2009 9:07 P.M. ORIGIN SCAN US 10/23/2009 7:37 P.M. BILLING INFORMATION RECEIVED damnit i want them NOW! It makes me mad to kno that they are just sitting somewhere about 10 minutes away |
Toledo,
OH
U.S.
Post Number: 375 Registered: Dec-08
| Posted on Friday, October 30, 2009 - 11:24 am: |
so i went into work yesterday at 5 upset trhat my speakers still hadnt arrived. got home at 1130, and they were on my bed. i was happy. i installed then at 1 a.m. last night and i have to say, i can see why everyone is on the DLS train. thanks for the help everyone! special thanks to wicked... no h0m0 |
Gold Member Username: Bonhamd
Traverse City,
MI
Post Number: 1969 Registered: Nov-07
| Posted on Friday, October 30, 2009 - 11:51 am: |
mmm h0mos.. |
