Thread: Found a free Cutlist program... |
Gold Member Username: •cam•
BC
Post Number: 2587 Registered: Nov-06
| Posted on Monday, October 19, 2009 - 11:19 pm: |
http://www.delphiforfun.com/Programs/CutList.htm I've been looking for something like this for a long time and I figured some of you could make use of it too. F paying for a program I might use 3 times a year... Scroll to the bottom to download. |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 5033 Registered: Mar-06
| Posted on Wednesday, October 21, 2009 - 11:03 pm: |
yes, that one is good. Ive used it a few times. I find if i make the ply 97x49 it will get better solutions, Also, I find i can fit more on it doing it manualy instead of letting it do it. Kinda like tetris.. Thing with that way is that you have to rough cut it first, then do a final straight cut. I believe one comment I got before from one of my lay outs was, "are you going to use a jigsaw on that?" But if I can squeeze them all on 1 sheet, so be it, better then spending another 25 on a sheet to only use like 2x2 of it. |
Silver Member Username: 813thumper
Tampa,
FL
United States
Post Number: 120 Registered: Sep-09
| Posted on Wednesday, October 21, 2009 - 11:52 pm: |
daammmm dudee.. as much as i love my Mac.. there are so many programs i cant run on it that require a windows OS |
Silver Member Username: Boomtank
Rochester,
NY
Post Number: 650 Registered: Oct-06
| Posted on Thursday, October 22, 2009 - 08:57 am: |
Pre-Vista Windows FTW Hopefully Windows7 is better then Vista. |
Platinum Member Username: Insearchofbass
York,
Pennsylvania
Post Number: 12805 Registered: Jun-04
| Posted on Wednesday, October 28, 2009 - 01:28 am: |
This will be usefull. |
