Thread: 2 amps or 1?? |
New member Username: Sgreer
Post Number: 3 Registered: Oct-09
| Posted on Sunday, October 18, 2009 - 04:34 pm: |
Hi. I am going to run 4 infinity kappas and a 12" Kicker. Would it be better to buy one amp for the speakers and one for the sub, or buy one 5 channel amp for everything? |
Bronze Member Username: Domenico
Glendale,
AZ
Post Number: 87 Registered: Apr-09
| Posted on Sunday, October 18, 2009 - 05:13 pm: |
Get one multi chnl amp for the kappas. &+ Get on mono amp for the kicker. For the kicker make sure you get a custom box.. will sound so much better. |
Glendale,
AZ
Post Number: 88 Registered: Apr-09
| Posted on Sunday, October 18, 2009 - 05:14 pm: |
also, if you need help with picking out an amp ill be more then happy to help  |
Post Number: 5 Registered: Oct-09
| Posted on Sunday, October 18, 2009 - 07:36 pm: |
ok well thank you so much. its nice to finally get a response from someone lol. My Kappas are 75w RMS so Im going to get a Alpine MRP-f300 for those. And for my sub which is a 12" Kicker that runs at 400 RMS at 2 ohm I am either getting the Alpine MRP-m500 or a Kicker zx400.1. I am leaning towards the Kicker because it has a bass control remote. What do you think? |
Gold Member Username: Bonhamd
Traverse City,
MI
Post Number: 1956 Registered: Nov-07
| Posted on Monday, October 19, 2009 - 10:53 am: |
dont do that you do not want to run different subs what infinity subs do you have (model # and voice coil config) |
Platinum Member Username: Insearchofbass
York,
Pennsylvania
Post Number: 12670 Registered: Jun-04
| Posted on Monday, October 19, 2009 - 05:41 pm: |
Hes only running one sub. |
Post Number: 6 Registered: Oct-09
| Posted on Monday, October 19, 2009 - 09:18 pm: |
iv got 4 Infinity Kappa speakers and 1 Kicker sub Which amp is better for the 400w RMS Kicker sub. It will be ran at 2 ohm. Should i get the zx400.1 (400 x1) or a Alpine mrp-m500 (500 x 1)? |
Traverse City,
MI
Post Number: 1957 Registered: Nov-07
| Posted on Tuesday, October 20, 2009 - 11:12 am: |
ahh i see. my bad. i thought you had 4 kappa subs and 1 kicker sub |
Post Number: 7 Registered: Oct-09
| Posted on Tuesday, October 20, 2009 - 05:15 pm: |
its ok, I was unclear in describing it. Can anyone give me a suggestion between the Kicker and Alpine amps for the sub? |
Traverse City,
MI
Post Number: 1958 Registered: Nov-07
| Posted on Tuesday, October 20, 2009 - 05:41 pm: |
both great options for amps what is your budget for both amps |
Post Number: 8 Registered: Oct-09
| Posted on Tuesday, October 20, 2009 - 07:31 pm: |
well i can get either one for around 150 new. i have another question if you dont mind... if my speakers and sub are both made to be ran at 2 ohm (the speakers and amp dont even have a power rating for 4 ohm), do i have to wire them a certain way or just hook everything up and it will automaticly be running at 2 ohm? |
