Home > Message Board > Car Audio > Amplifiers > What gauge do i need
Author Thread: What gauge do i need
Username: Kenny_boy
hi i'm runinng a 500wat bazooka amp and a 12" bassworx sub hooked up to it what size of wire should i be runing to my amp
Username: Insearchofbass
York, Pennsylvania
Post Number: 12634
8 gauge
Username: Tuloud
Post Number: 19
I would recommend using a good quaility brand 4ga amp kit if dont have one already. make sure you get the right fuse rating also.Internet has pretty good 4ga kits for a decent price. plus if plan to upgrade in the future you will still probably be able to use the same wire size unless you want alot more powerful equipment.
I dont no what bazooka amp you have but I can bet it isnt running at 500 wrms so see at a stereo store if 4ga will fit in the power terminals. Might fit 8ga wire better
Username: Kenny_boy
thx for your help
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Amplifiers > What gauge do i need [ « Previous ] [ Next » ]
