Home > Message Board > Car Audio > Subwoofers > Archive through November 02, 2009 > **Calling out Steve Miller & RD Audio...
Author Thread: **Calling out Steve Miller & RD Audio**
Username: Alzero
Steve, we've already seen quite a bit from you about the fact that you have stayed with the same buildhouse as your v1 amps and that the quality has actually increased overall - readers, please reference Steve's post on CA.com for this information. Lies #1 and #2 right there. You're not with Zenon anymore. You decreased cost and went with a lower quality buildhouse in China. For Christ's sake, your boxes say Made in China on them. Puhhhlease?
I'm not going to be the total @$$hole and give up the buildhouse you're working with now. BUT
COULD YOU STOP LYING TO US ALREADY?!? On October 10th you launched your presale for the 2200v2's over on CACO. See: http://www.caraudioclassifieds.org/forum/showthread.php?t=19489 In your presale post, you claim your amps do over TWO THOUSAND EIGHT HUNDRED WATTS AT 14.4 - spelled out for emphasis. Folks, thats 2800+ w RMS at 1 ohm a 14.4v that is being claimed. Steve, your own freaking buildhouse even states the following:
RMS @ 1 Ohm(<1% DISTORTION) 2300W
Here's where you're going to claim I'm full of crap. So let's just get down to it shall we? I'm not. I know exactly where your amp is coming from, who is building it, etc. It's a stock design - you didn't even purchase your own heatsink tooling. Just used what they had - perfectly fine. But stated for the purpose of...I know what I'm talking about. The following is what your buildhouse states. Of all parties involved, they have every reason to overstate their claims in an attempt to improve their sales. They still state the following though:
RMS @ 2 Ohm(<1% DISTORTION) 1600W
RMS @ 4 Ohm(<1% DISTORTION) 904W
Frequency Response 15Hz~270Hz
S/N Ratio >80dB
THD <0.15%
Input Level 0.2-6V
LPF 35Hz~270Hz
SUBSONIC Filter 15Hz~35Hz
Bass Boost Level 0~9dB
Components & PCB Double Side Board
Dimension(L x W x H) 453 x 250 x 70mm
So Steve, can you stop lying to us already? Please? It's getting old. I will not reveal any other info regarding your amplifiers so long as you admit the discrepancies you've stated. Your buildhouse will be kept a secret. No other info will be revealed. I won't even take this to other more-trafficked forums. Continue to lie though, and I promise you're gonna have a much larger issue on your hands - especially when some of the other forums get involved. Enough is enough.
IF YOU WANT TO CLAIM 2800+w RMS - PROVE IT. Clamp your 2200v2 for all to see. If it really does the power you claim, then you'll have surprised us all and you can go show off the video to everyone from eCoustics, to CA, to CACO, etc.
Lastly, if this amp does 2800+w as you claim....why the heck did you build a 3250v2?
Folks, I'm not here to attack the amp. I'm sure the amp will produce output according to the buildhouse's specifications listed above. The amp is probably fine. It's the claims that Mr. Miller and RD Audio are making that I have a problem with.
Stop lying Steve.
Username: Cozce
St. Louis ILLside, Pronounced: ...
U.S.A.
Post Number: 849
snap
Username: Boomtank
Rochester, NY
Post Number: 643
what was the distortion at the rated 2800watts? Maybe he was just saying at higher distortion it will produce more power, which is true isn't it?
Username: Alzero
Amps aren't rated at 10%+ THD these days...they're rated at 1% or lower. But if Steve decided to rate at some abnormally high and audible level of distortion (like what you're suggesting), then his claimed power is thoroughly deceptive and cause for major concern.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 7364
I've been saying this for a while.. I just never went that into detail haha
Username: Rovin
1 15 = 152.5 DBs ...
Trinidad & T...
Post Number: 15561
oh oh .....
Username: Bonhamd
Traverse City, MI
Post Number: 1951
is that unusual? is it usually up to 60-70 or so?
or am i just a big fat noob?
Username: Rovin
Trinidad & T...
Post Number: 15562
^u sure ur not confusing SSF with LPF ...
Username: Kingandsons07
TEAM NEBRASKA
Lincoln,NE
Post Number: 946
oh wow
Username: Nyyfan13
Northern VA
Post Number: 11639
Who are you? If you don't mind me asking.
Username: Bonhamd
Traverse City, MI
Post Number: 1952
i thought that if you have a ported or BP box, you set the SS filter to the same frequency the port is tuned to, to cut off frequencies below your tuning.
this stops your sub from unloading, correct?
i have a box tuned to 40 hz....i know 5 hz probably isnt a big deal but i wouldnt want to run the risk of my sub blowing up
im not sure though........
Username: Boomtank
Rochester, NY
Post Number: 644
Looks like someone was too late on the pre-order and is a little angry.
Most Subsonic Filters I've every seen are 10-35hz or 15-35hz.
Not sure why a SUBwoofer amplifier would need to be cutoff any higher then 35hz let alone 70hz.
My 6.5's in my doors go down to 45 hz themselfs lol.
Username: Ericmb
Waycross, Georgia
United States
Post Number: 202
daniel, i guess that is unusual. most do go higher, but if your box isnt tuned that high, why even need a setting for that high? seems like it would be for more sq purposes or just some low tuned daily systems.. idk, i maybe be a big idiot...
Username: Bonhamd
Traverse City, MI
Post Number: 1953
i thought my 3250 was 10-60
i doubt 5hz below port tuning would be a huge deal but i just thought it was odd, as i was under the impression that most amps went up to 60 or 70
Username: Philly306
If youre going to give...
Post Number: 1449
i read that entire first post just to realize that i wasted my time and that you are b!tching over 500w. Im no fan of RD but its something else to see people feel so butthurt about things to try thier best to put together a well thoughtout post to slam a company.
newsflash! RD isn't the first company to lie!
Diamond Member
Www.stainles...
.ecrater.com
Post Number: 21418
Let the mud slinging begin?
Username: Teamrevolution
ATLANTA, GA
Post Number: 800
look at my posts bud and anyone who called about the new amps. I stated plenty it is new build house.
You cant even buy zenon 3000w amps at the price i am selling them.
OH and yes the 2200v2 does 28xx . The 1800.1 is the one thaT does 2300.
fuuny how you create a name on a forum you think your ip cant be pulled.
So please read what i wrote or told people. At 425 its not a zenon amp but it does as good. Secondly yes the 2200 does 2800 it is the 1800 that does 2300. OH thats because the 2200v2 is new from build house and we are first to use it. Please do a little more research before you run your mouth and try to call someone out.
third never once said it was zenon amp and stated many times we went to diff build house to offer more affordable line.
ANYTHING ELSE YOU WANT TO KNOW?
ATLANTA, GA
Post Number: 801
so can i call you out?
why are you hiding behind a BS name who are you?
TEAM NEBRASKA
Lincoln,NE
Post Number: 948
"Thread jacking happen right here"
hey Steve i take it the 3250s are in or whats happening there
thanks
ATLANTA, GA
Post Number: 802
yes and repaired v1 amp is at customs waiting to be released.
ATLANTA, GA
Post Number: 803
LOL all our amplifiers are very under rated now.
ATLANTA, GA
Post Number: 804
1000.1 = 1350+ = rated 1000w
1750 = 1900+ = rated 1750w
1800.1 = 2300+ = rated 1800w
2200 = 2800+ = rated 2200w
3250 = 3350+ = rated 3000w
d5 = 3800+ = rated 2000w
d9 = 5400+ = rated 3600 w
Username: 04redmach1
Www.rdaudio.net, GA
Post Number: 2620
"Amps aren't rated at 10%+ THD these days...they're rated at 1% or lower. But if Steve decided to rate at some abnormally high and audible level of distortion (like what you're suggesting), then his claimed power is thoroughly deceptive and cause for major concern"
Thought I would correct your statement here. Amps are rated at <1%THD, but at 4 ohm. You are comparing a 1 ohm load to a 4 ohm THD rating.
Kevin
TEAM NEBRASKA
Lincoln,NE
Post Number: 949
thanks Steve, i kinda miss my amp
Username: Hittin1
TEAM REVOLUTION, La.
Lake Charles...
Post Number: 4024
I'm sure some will clamp one of the v2's... Instead of acting like a pr!ck coming on a forum to talk sh_it, just buy an amp and get it tested ... The correct way, by an unbiased third-party then call him out if you are right... That way you won't come across as a whiny b!tch hiding behind a BS name... As you do now.
Username: Hdubb
Team Revolution
Post Number: 4240
blah blah blah. blah blah blah. blah blah blah.
lets beat a dead horse to death.
Username: Domenico
Glendale, AZ
Post Number: 79
X2
Username: Wickedbass
TheWicked
Post Number: 936
Anybody else want some popcorn??? I has plenty.Upload
Username: Poprocks
Post Number: 287
Username: 813thumper
Tampa, FL
United States
Post Number: 93
popcorn for me plz??
TheWicked
Post Number: 939
Sure.
Tampa, FL
United States
Post Number: 96
mmmm.. popcorn. more drama on the side?
ATLANTA, GA
Post Number: 807
whats good movie to go see? I was thinking of going to one tonight
i seen that paranormal the other day it was ok.
Anything you guys seen that is real good?
Tampa, FL
United States
Post Number: 98
Couples retreat looks funny. id go see that.
Username: Mpinto19k
Colorado Springs/, CO
Post Number: 317
Zombie Land is pretty damn good, I really liked it. If you haven't seen it I'd def. suggest going
Diamond Member
Www.stainles...
.ecrater.com
Post Number: 21433
Cloudy with a chance of meatballs.
Kids loved it.
Username: Wackzirth88
K-town, Il
U.S.
Post Number: 157
yep heard zombieland kicked as$
Username: Mpinto19k
Post Number: 318
It did! I never really go to movies but going to see that was def. worth it
TheWicked
Post Number: 941
I haven't been to the movies in forever. I might go tonight now that Im thinkin' about it. The last movie I seen in theaters was Beowulf in 3D, was a bit drunk at the time too. There were a couple of times when I thought I was about to get hit in the face with a sword/arrow.
Tampa, FL
United States
Post Number: 100
"The Box" looks good but its not out yet.
Username: Snowball123
West Allis, WI
Post Number: 3240
really you went there drunk wicked?
weird cause it's not like you drink every night...
Username: Simple_smith
Lapeer, Michigan
United States
Post Number: 123
yeah "The Box" looks sweet.
would you press the button?
P.S. if you haven't seen the previews, they get this box if they press the button they get a million dollars, but someone in the world dies (who they may or may not know).
TEAM NEBRASKA
Lincoln,NE
Post Number: 951
WOW haha humm about this
TheWicked
Post Number: 954
http://www.youtube.com/watch?v=ZxxPLDZnqwA
Username: Hittin1
Lake Charles...
Post Number: 4033
I haven't seen the previews for it yet, but .... (at the risk of dating myself) There was an episode of Albert Hitchcock that was almost exactly like what was described a few post's ago... The box had a button... The proposal was a large sum of money if he pushed the button, and someone who he did not know and have never met would be killed... That button and the thought of all that money drove the guy crazy. He eventually pushed the button... He wanted that money... If you know anything about Alfred Hitchcock and how he ended the show, he ended this one by the guy who made the proposal congratulated him on the money he was gonna recieve.. Now he didn't have to stress over the decision anymore... Then as he's leaving, he says something like, "Well, I gotta go... The deed has been done and you have your money... Now you can get you some rest... I've just got to drop this button off to someone else.................Someone that you do not know...and have never met".. Then the credits rolled.. I liked that episide.. Think it was my 2nd favorite. My Favorite was a little more twisted and threw me for a loop back then..
Username: M0nstar
Toledo, OH
U.S.
Post Number: 356
i took my box out for awhile and just put it back in today... i realized that "we be steady mobbin" is probably the only song that i could pull the power wire on my highs amp and listen to the whole song thru.
i say this because i use an RD amp and have been since.... january?
i <3 RD
and kevin and steve.
Username: Th3pwn3r
I compensate...
Post Number: 9424
What a terrible thread right from the very start.
Diamond Member
Post Number: 23530
steve how can you watch paranormal activity. that movie is the scariest movie i've seen. i walked out of the theater after 40 minutes. i couldn't take it anymore.
Username: Ducka
Shelby Twp., MI
United States
Post Number: 1267
Sweet, I should go see that movie then.
Username: Hittin1
Lake Charles...
Post Number: 4038
X2^^^ lmao. Chad= Puss_y
Username: Mpinto19k
Post Number: 321
lmao at this whole thread
But is that movie actually scary? Looked really stupid to me
Username: Quirky
SA, Texas
Post Number: 377
Ha Looks like the original subject took a sharp turn from a guy full out fussing about a company, to what movies are out.
As Phil said, "RD isn't the first company to lie!" It should not be a huge surprise a company may bend the truth a bit. Not taking any position weather they did or did not however I would like to think RD is a respectable company.
This thread would have been more productive if the op had brought the issue to our attention with a valid debate/discussion to uncover the truth, rather than a blatant attack on the company.
Username: Splmonster
Akron, OH
Post Number: 1578
hey steve what does the 850 do? is it under rated too?
Username: Msand951
San jacinto, Ca
Usa
Post Number: 206
i heard paranormal activy sucks. Its being compared to another blair witch project type film. I havent seen it but i was told not to waste my time.
Username: M0nstar
Toledo, OH
U.S.
Post Number: 370
anyone go to se saw VI tonight?
it better not suck as much as the last 2
Username: Mpinto19k
Post Number: 324
Come on now dude of course its going to fu<king suck and more like the last 4
Username: Th3pwn3r
I compensate...
Post Number: 9429
Haha, I agree Mauricio. They are definitely some pretty terrible movies.
Home > Message Board > Car Audio > Subwoofers > Archive through November 02, 2009 > **Calling out Steve Miller & RD Audio... [ « Previous ] [ Next » ]
